Question about Canon PIXMA MP760 All-In-One InkJet Printer
3eBK does not work
I have changed the cartrdige and am unable to get the black 3eBK to print despite cleaning processes
Noggin
  • 944 Answers
SOURCE: Canon iP5000 not printing black
Here is the link to the user guide if you need it; http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10439 If you have performed all the operations in there with no success, then the part of the printhead that is under the 6bk has some blockages. This is best cleaned by dripping some ink flush solution (use gin if you have none) into the print head from above (just at the point where the hole on the ink cartridge would sit. Very gently swab with a q-tip from below with more fluid. After a day or so with the fluid penetrating from the top, clean the bottom again, clean out any excess fluid you can from the top (don't get any q-tip fluff in there). Then run a clean/test again. Hopefully this can solve your problem after a few cleans, but blocked Canon printheads are not always unblockable. You can purchase the complete replacement printhead, although I wasn't able to find a price - this link for service; http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=184&modelid=10439 Hope this helps :)
Posted on Jul 20, 2007
  • 92 Answers
SOURCE: The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 26, 2009
  • 1810 Answers
SOURCE: After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Posted on Aug 03, 2009
SOURCE: IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Posted on Sep 07, 2009
  • 142 Answers
SOURCE: Hi, our black 3ebk will not print. we have deep
Check if there is a tape over the top vent intended to let air into the ink tank and so ink can flow out to the writing head.
Posted on Sep 27, 2009
My black ink doesn't print well despite changing cartridge and ink smears appear on the image when printing. What can I do?
have u gone through the re-alignment process and clean print heads as u should do it after every change.
May 19, 2015 | Brother Lc1240 / Lc1220 Set Of 4 Compat...
Not printing red or pink
Hi patti,
Did you check the black ink cartrdige ???? To get red, their needs to be black ink involved which will darken the pink and give you red.
Also, make sure the nozzles are clean on the printer's print head. Take a Q-tip and alcohol and clean the printhead on the printer itself. Remove the cartrdige first. Clen the underside of the cartrdige as well.
Don't worry, alcohol won't harm the printheads because it dries instantly.
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us ForBrother Printer Support
Feb 17, 2014 | Brother MFC9320CW All-In-One Printer
Can't unclog black 3eBK nozzle.
If you said you replaced cartridges with new ones and it still doesn't work, the printer is the issue and may need to be replaced.
Nov 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Sep 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
3eBk will not print. Canon MP780
Replacing the printhead may work, but it could be a problem with the cleaning assembly. Take out the 3ebk and run a cleaning, if the ink goes away on the pad where the ink cart. goes, then clean assy. is OK, and you need a new printhead.
Jul 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Black ink 3eBk wont print
Ok what you need to do is make sure that the ink cartridge is properly inserted all the way. If it's not then you won't be able to print out black ink at all.
Jun 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Dec 24, 2008 | Canon PIXMA iP4000R InkJet Printer
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
65 people viewed this question
old marine
old marine
