Question about Packard Bell (190169) Power Supply
Power switch light is on but no other poweris getting through, changed the power supply but same problem. light comes on power button but power supply fan doesn't even come on.
    President:
  • 632 Answers
No beeps are heard, no CPU fan is turning on, only blinking yellow light. This brand usually experiences this problem.
  1. First, check the power supply. Disconnect connectors from the board and make a jumper wire for the green wire to any black wire. If the PS fan does not spin then it's busted, else proceed below.
  2. Reconnect connectors except the one with 4 wires, 2 yellow and 2 black, then switch on. If CPU fan turns on then you have a bad processor.
  3. If the fan is still not turning on then check the USB port pins for short circuit.. disconnect it from the board and switch on.
  4. Do the same with other hardware connected to the board.
PS: The metallic casing of computers must be connected to the common ground of the power utility to protect it from stray currents that result to damage of sensitive components such as processors, memory and hard disks.
Posted on Sep 26, 2009
I have a 36'olevia HDTV.......it has a detachable power cord and it also has a power switch in back. When I plugged it into the wall,turned on the power switch, and pressed the power button, I got no
The light is likely the standby light if it is on when set is off and goes out when set turned on or changes color when set comes on.
The fact the light is on should rule OUT the main fuse for the set, most likely the problem is the power supply itself inside the set
The Standby supply is part of the main power supply and when set is plugged in and off it runs 7/24.
Have you had problems where the set was "hard to turn on" or you had to try to turn it on several times before it would stay on?
Dec 07, 2012 | Televison & Video
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
Not working or coming on
Check to make sure the power cord you are using is getting 120 volts and that it is plugged in properly to the pc. If you are sure your power cord is powering to 120 volts, plug it in to the computer and see if the power supply light (in the back of the computer) is coming on. If it is, then the power supply is good, if not, you need a new power supply unit. If your power supply does not have a power light on it, listen for the cooling fans to come on when you press the power button, if they don't, it is very possible that the power supply is bad and will need to be changed.
Feb 10, 2011 | Computers & Internet
The TV will not turn on. No power light
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Jun 22, 2010 | Protron PLTV3250 32 in. LCD Television
Our HP Media center pc will not power on. I push the button and the button does not turn green or power on. A green light on the back flickers, but that is all. I forgot to ask if it could just be the...
Make sure the switch on the back of the power supply is set to the position that has the line on it. If you still can't get any power, then try another known good power supply, if you still don't get any power then you know the motheroard is bad.
Jun 12, 2009 | HP Pavilion Replacement 200w Micro ATX PS3...
Computer will not turn on
May sound strange, but is the power supply switch in the correct position?
If the button is pressed, makes your continuity test, and not even the fans come on, check that the switch jumper has not come loose from the motherboard, and finally, if the motherboard is plugged in and no fan comes on when you push the power button, there may be chipset damage from an electrical surge or overheating.
In this case, a new mobo is your only option.
Jan 20, 2009 | Dell Dimension 4600 PC Desktop
Usb power issues
Some systems will try to boot up on a usb device such as an IPod or a external hard drive.
It should be unplugged to get it to boot properly.
Oct 31, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Nov 26, 2007 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Packard Bell (190169) Power Supply Logo
214 people viewed this question
Top Packard Bell Computers & Internet Experts
carey w mason
carey w mason
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
