Question about Pentax Optio E40 Digital Camera
My Pentax Optio E40 turns on but the shutter release button seems to be locked or doesn't work.
I have pentax digital camera how to turn off green mode from pentax optio E40
Press cursor-down, then use the cursor keys to select the desired mode. See the descriptions beginning on page 50 of this manual: http://c758710.r10.cf2.rackcdn.com/files/support/manual/356_1314745005-527808376_manual.pdf
Jul 29, 2013 | Pentax Optio E40 Digital Camera
I have a pentax optio E40 camera. The screen reads card locked and I cant get it open
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try a different card.
Oct 28, 2011 | Pentax Optio E40 Digital Camera
I have a pentax optio E40. The screen reads card lock and i cannot get it unlocked
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
If that doesn't do it, append a comment to this thread and we can go on from there.
How to cancel ''green mode''? camera has 8.0 megapixels Pentax Lens, 3 x Optical Zoom 6.3mm - 18.9mm
The Green mode locks out the user from the camera menu. To cancel the Green mode you must press the Green button again.hope this helps
Apr 07, 2010 | Pentax Optio E40 Digital Camera
My camera is way to slow to take a picture
If you read the reviews on A10 it has something like 1.73 seconds shutter lag, which is very slow to some other cameras with only 0.3 shutter lag. Redeuce the pixels to 6mb. Also a weak battery and maybe a under performing m.card add to your camera seem to be slower usual.
jam
Jun 07, 2008 | Pentax Optio A10 Digital Camera
Shutter release button
I don't know your particular model.
Some cameras have a safety switch, or a safety selection in the menu. Check for this.
It is also possible that the switch is defective, or there is fault on the circuit board that is causing it to not be read by the uPC. For this type of repair, you would have to have the camera serviced by the manufacture or their rep.
Jerry G.
Jun 06, 2008 | Pentax Optio 30 Digital Camera
My Pentax Optio E40 Camera
The built-in memory only has about 8 pictures or so. You have to buy a memory card to insert in the same section where the batteries are inserted.
Apr 03, 2008 | Pentax Optio E40 Digital Camera
No matter what I do, my camera keeps giving me a "Battery Depleted" message whenever I try to turn it on. It's a Pentax Optio E40, and I've only had it a couple of weeks. It was working fine, but...
I had the same problem and checked the manual. If you haven't used the camera in a while and there were either no batteries or dead batteries in it, put in new batteries, keep it off, and WAIT a few minutes. Then try to turn it on. This helped with Pentax Optio E40.
Mar 24, 2008 | Pentax Cameras
Pentax Optio E40 Digital Camera Logo
118 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
