Question about Sony Cybershot DSC-H3 Digital Camera
Telephoto lens doesnt work
When I attach my telephoto lens the picture is the same as it was without it. It doesnt zoom any farther. I do have it set to tele in the conversion lens menu.
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things:
1. What kind of pictures do you intend to take?
2. Do you mind a heavy leans? Some are 10 pounds or more.
3. Your budget.
The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do...
For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures...
Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
Dec 18, 2015 | Canon EOS Rebel G 35mm SLR Camera
Canon g11 telephoto lens vignette
You have to zoom the camera lens out for that lens to work.
Feb 15, 2014 | Opteka 32x HD?² Telephoto Lens for Canon...
I did not get any instructions with my Opteka. Have tried to take photos with it. But they came out all blank. I used a tripod. Would like to know where I can down load instructions. Certainly not as good...
You did not provide enough information to determine what your problem is. For example, were the pictures all light or all dark. Knowing this lens, I will assume that they were all dark. So...
1) This is a very, very slow manual-focus lens. It will not auto focus. It must be manually focused very precisely because it has virtually no depth of field.
2) Depending on your camera, your internal light meter may not work. On my camera (Nikon D-90), it does. If it does not on yours and I suspect that may be your problem, you're going to have to shoot everything manually, i.e. setting the shutter speed and lens opening yourself. You can use your internal light meter to help you get started by taking your light reading before you install the lens...preferably using the aperture only setting where you set the aperture at f8 which I think is the speed of the Opteka and let the camera set the shutter speed. Make a note of the shutter speed then attach the Opteka to the camera and mount the lens on a tripod with the camera attached.
Then set your camera mode to manual and set the aperture to match the lens (f8, I think). Set the shutter speed at the speed you noted earlier. Shoot a picture using a remote shutter release or the self timer. This lens is so slow that unless you're in exceptionally bright conditions you will get fuzzy pictures due to camera movement at full zoom of 1200m and above if you're using the 2X doubler. I would start shooting at minimum zoom of 650 without the 2X doubler. Shoot a picture. and check the result.
You should have an image but it may be too light or too dark.
If its too light you'll need to increase the shutter speed or stop down the aperture to, say, f11...or both. Make the adjustment and shoot another picture. Remember that if you increase the aperture, you increase your depth of field, making focus less critical. If you increase the shutter speed you make camera or subject movement less critical.
If it's too dark, you can only increase the shutter speed because you can't open the lens any wider than f8. Make the adjustment and shoot the picture.
Keep doing this until the pictures are the way you want them.
This is a decent lens for the price and worth the little money they cost if you can't afford $10,000 plus for a high quality telephoto lens of this size. I would forget about the 2X doubler because as others have said, it further reduces the speed of an already very slow lens with such a high rate of magnification that a knat landing on the lens could cause the picture to blur from movement.
Jun 26, 2011 | Opteka 650-2600mm High Definition...
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
I have a canon ixus 70. When I use the zoom facility the pictures become blurred. WHY
Believe it to be a camera fault. Reason: zoom feature makes the lens extend for telephoto work, therefore, the autofocus feature should be working at any distance you set the lens for and your shots should be clear. Could be an autofocus problem or the lens and CCD are misaligned at the telephoto position. Have the camera checked by a qualified repairperson. Get an estimate first. You may want to ask this question at the Canon website also.
Aug 22, 2008 | Canon Cameras
Flashless photograghy
If you set the camera to P (program) the flash will not pop up automatically but the camera will still control the shutter speed and aperature settings automatically. Also with the lens you are using you should probably have a tripod which will help you hold the camera more steady.
Jun 10, 2008 | Canon EOS 40D Digital Camera
Adding a telephoto lens
Try zooming in. That usually gets rid of the "vignetting" you are experinecing.
May 02, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
How does a telephote lens work on the C2000Z???
You must have the lens extended all the way or you get a halo effect as if your taking the picture through a tube. This might be interesting in some instances. I have the 1.4x for my 2000z and it works very well although it is a little cumbersome.
Sep 11, 2005 | Olympus Camedia C-2000 Zoom Digital Camera
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Sony Cybershot DSC-H3 Digital Camera Logo
59 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
