Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, chances
are that your batteries need to be replaced because they're just too worn to properly power the camera.
And then, of course, there's the possibility that your camera may have
a problem that requires professional repair.
After inserting memory stick and powering it on DSC 60, error reported in Memory stick error"...
(More)
After inserting memory stick and powering it on DSC 60, error reported in Memory stick error" How can I upgrade firmware for dsc 60?
hi: The first i am really thank for your help! I encounter an problem. i make an application about...
(More)
hi: The first i am really thank for your help! I encounter an problem. i make an application about camera. when i statr my application,and then open the couver in the back of mobile telephone,the system camera application well be opened. i want my application exclusive the screen.what should I do, i could stop the system camera application! thanks
