Question about Acer Aspire 5100 Notebook
Pqservice i deleted it does any 1 know how to find another
  • 177 Answers
Try windows update, and instead of high priority updates, click on custom, and then optional software and optional hardware. Click them all, and the high priority will update too, and this could solve the problem
Posted on Sep 26, 2009
Acer eRecovery management Restore system to factor default but I don't know the password
Locate and Unhide Hidden Rescue Partition
  • 1 Access the Diskpart command prompt. Acer stores custom eRecovery passwords on your computer in PQService, a hidden rescue partition. Locating this partition requires accessing the Diskpart utility from the command prompt. Diskpart allows you to run a scan on your hard drive and bring up hidden partitions. To access Diskpart, go to Start and type "cmd" in the search bar to bring up the black command prompt box, and then type "diskpart" at the prompt to switch to a Diskpart prompt. Depending on your computer, a new command prompt may open with the Diskpart prompt.
  • 2 Scan your computer configuration. At the Diskpart prompt, type "rescan" to run a system configuration check. When the scan finishes, you will receive a message informing you the scan is complete. At the command prompt, type "list disks" to bring up available disks and then type "select disk 0."
  • 3 Locate the hidden partition. At the command prompt, type "list partition" to view a list of partitions on your disk. Locate the partition with no name and a size of approximately 10GB. At the command prompt, type "select partition (number)."
  • 4 Determine the partition type and unhide the partition. The hidden PQService partition will be either a type 27 or a type 12 partition. If the partition is type 27, unhide it by typing "set id=07 override," and if a type 12, then unhide it by typing "set id=0B" at the command prompt.
  • 5 View the PQService partition. Return to the disk containing PQService by typing "select disk 0" at the command prompt, and then type "list volume" to view the contents of the disk. PQService will be visible in the list, preceded by a number. Type "select volume (number)" and then assign PQService a new drive letter so you will be able to open and view it from your computer interface window. At the command prompt, type "assign letter=f."
Reset eRecovery Password
  • 1 Open PQService. Navigate to the drive containing PQService. Find the file "aimdrs.dat." Right-click on the file and select "Open with" and then "Textpad," "Notepad" or another text editor you prefer.
  • 2 Open the file and find the password. Open the file with your text editor and locate the eRecovery password. Look for a line that reads, "Password=password name," "Hint=the password hint." Write down the password and close the file.
  • 3 Open eRecovery using the recovered password and follow the instructions to create a new password.
Read more
May 23, 2015 | Acer Computers & Internet
Tip
How to Reset an Password for Acer eRecovery
Acer eRecovery is a vendor-specific method you can use to restore your computer to its original factory settings, or to custom settings you create and store on your hard drive or other removable media. eRecovery also contains a back-up utility you can use to back up data to your hard drive or other removable media. Access to eRecovery requires you to use the default "000000"password or one you select. While it is important to store a custom password in a safe location, if you lose or forget it, there are steps you can take to reset your Acer eRecovery password.
02d2ca3.pngstep 1. To access Diskpart, go to "Start" and type "cmd" in the Search bar to bring up the black command prompt box, and then type "diskpart" at the prompt to switch to a Diskpart prompt. Depending on your computer, a new command prompt may open with the Diskpart prompt.
Step 2. Scan your computer configuration. At the Diskpart prompt, type "rescan" to run a system configuration check. When the scan finishes, you will receive a message informing you the scan is complete. At the command prompt, type "list disks" to bring up available disks and then type "select disk 0."
Step 3. Locate the hidden partition. At the command prompt, type "list partition" to view a list of partitions on your disk. Locate the partition with no name and a size of approximately 10 GB. At the command prompt, type "select partition (number)."
Step 4. Determine the partition type and unhide the partition. The hidden PQService partition will be either a type 27 or a type 12 partition. If the partition is type 27, unhide it by typing "set id=07 override," and if a type 12, then unhide it by typing "set id=0B" at the command prompt.
Step 5. View PQService partition. Return to the disk containing PQService by typing "select disk 0" at the command prompt, and then type "list volume" to view the contents of the disk. PQService will be visible in the list, preceded by a number. Type "select volume (number)" and then assign PQService a new drive letter so you will be able to open and view it from your computer interface window. At the command prompt, type "assign letter=f."
Step 1. Open PQService. Navigate to the drive containing PQService. If you are using Windows XP, use My Computer; if you are using windows Vista, use Computer. Find the file "aimdrs.dat." Right click on the file and select "Open with" and then "Textpad," "Notepad," or whatever text editor you prefer.
Step 2. Open file and find password. Open the file with your text editor and locate the eRecovery password. Look for a line that reads, "Password=password name," "Hint=the password hint." Write down the password and close the file.
Step 3. Open eRecovery using the recovered password and follow instructions to create a new password.
Partner: Windows Password Recovery Tool
Contact:annyyu22@gmail.com
Blog:http://www.blog.lostwindowspassword.com
on May 18, 2010 | Computers & Internet
I have deleted pqservice please help
Start -> Search -> pqservice -> Start search -> when this Acer Recovery Utility is found single left click to highlight it -> right click on highlighted area -> send to -> Desktop (create shortcut) -> double click on new pqservice desktop icon to test.
If the above does not fix the problem:
start -> all programs -> accessories -> system tools -> system restore -> restore my computer to an earlier time -> next -> select a bold date on the calendar to the left and an even in the event schedule to the right that both precede/predate whatever change in settings that caused your application's icon or file directory to change configuration -> restore -> restart computer without interrupting to complete restore process -> look for the lost Utility in its usual place.
If none of these resolve the problem, then the Utility may have accidentally been deleted by yourself or perhaps by another user, without your knowledge and you may have to download and reinstall the missing Utility from the Acer Support Drivers and Utilities Download website.
Acer Utilities Download Webpage (see drop down menu beside Empowering Technology and Utilities and look under eData Security):
http://support.acer-euro.com/drivers/notebook/as_5315.html
Nov 24, 2011 | Acer Aspire 5315 Notebook
PQSERVICE
I'm trying a backup of my Aspire One PQSERVICE to DVD after a near catastrophic partitioning experiment.
So far, I've booted from a Knoppix live CD and I'm trying partimage to copy the contents of the PQSERVICE to an image file on an external usb hard drive. Hopefully I can burn the image to DVD-R. So far, it looks promising.... even if I can't make a DVD-R from the image, I can use partimage to restore the PQSERVICE from the image file if I have to.
Another option would be to boot a knoppix live CD and just copy the contents of PQSERVICE to another disk or partition (not NTFS though). Linux doesn't care about the hidden drive partition settings that Windows uses.
Sep 02, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 3680 PQSERVICE
if you have installed vista and change it to xp, you should first delete or reformat your current OS (Operating System) which I believe is the ur vista.
formatting OS:
-insert your xp disk then press F8
-click format or delete files ( i don't know the exact message that will appear on the screen)
-then install windows XP (just follow the instruction that you will see on the screen)
hope this would help you solve your problem..
thanks.. :)
Aug 22, 2008 | Acer Aspire 5610-4648 Notebook
Acer d2d recovery problem
Idiot. You deleted the partition containing the D2D.
Mar 03, 2008 | Computers & Internet
D2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Oct 16, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
