Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Trying to dubb video from hard drive to dvd-r and error 14 keeps coming up on the screen. thanks sylvie
  • 4 Answers
Well, by now I'm sure that you know to clear the code, you press the "Display" button a few times. As for getting the Toshiba to actually burn a DVD, I'm not certain that I can help you there, as I've run into problems burning stuff. Unfortunately, it doesn't burn all the time, even if you use the same routine as the last successful burn.
Posted on Dec 13, 2010
I have a 1/4 red ring in the lower right how bad is this and what do i do
That denotes some sort of hardware error... there should also be an error o the screen when you boot up the Xbox...
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Apr 19, 2011 | Microsoft Xbox 360 Console
Xbox is showing one red light in the lower right hand spot. How do I fix this
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
Sep 24, 2009 | Microsoft Xbox 360 Console
Our sony ps3 will not load games it keeps comimg
Either you have a bad hard drive which you could replace with a larger one or try using a DVD cleaning disk in the player if the issue is with the DVD drive. The disk player might need replacing. Good luck!
Sep 09, 2009 | Sony Playstation 3 (PS3) Console
It has the bottom left ring
Hello my name is Tim Ehrhart and I hope this helps The Specific Type of hardware failure can be determined by the error code displayed on the screen.
Please leave feedback as I am new and wanne gain a good rep. Thnk You
Mar 12, 2009 | Microsoft Xbox 360 Console
Error 14
Check to see if you are using 16X media. If so contact Toshiba for a fireware upgrade. If that is not the problem try cleaning the disc and cleaning the unit with a DVD Laser Lens cleaner. Then try again.
Mar 30, 2008 | Toshiba DR4 DVD Recorder
Freezing
Hey niKKiK,
Here's some things to try.
Remove the hard drive from the console, (while it's off of course), and then turn the console on without it. See if it freezes during gameplay.
There's a common issue with the 360's where the cache size (cache is just a fancy word for storage for data) gets too large, and the read/write speed between hard drive and dvd-rom gets too long, and causes the system to hang.
IF this is the case; where it doesn't freeze while the hard drive is out, you can do something simple to "clear the cache".
Turn the console back off, and put the hard drive back in.
Turn the 360 back on.
Locate the system section in the 360 dashboard.
select Memory, and then hard drive, and then press Y. (device options screen).
At this screen press these buttons in sequence:
X,X,left bumper, right bumper, X, X.
This brings up a maintenance screen. Press A for Yes.
Since you are playing a game, and there is no error message. I'm 86% sure this will solve your issue.
the other 14% that is unsure, is because it may in fact be a faulty system. If this advice doesn't help you out, I advise you to contact microsoft for further support. But you know what they'll do. They will surely have you send it in, and we all hate that. So I wish the best of luck with the issue.
-Chad
Dec 10, 2007 | Microsoft Xbox 360 Console
Screen replacement
there are screw covers on the face of the unit. remove them carefully so you dont scrath you case or screen. Simply remove the screws and you top half will come apart. Your next step is to remove the hinges. I use a small screw driver and pop them out. Hope this helps
Oct 06, 2007 | Nintendo Game Boy Advance SP Console
DMR E80H hard drive
DMR-E80H Hard drive problem seems to pretty common. My drive started making the famaous kerchunk noise tonight. After disassembly I see the drive is a ATA133 Maxtor drive....are you sure that you replaced it with the correct drive? I may contact Maxtor and try to get an RMA since the drive is only 3yrs old. Good Luck
Oct 09, 2006 | Panasonic DMR-E80H DVD Recorder
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
