Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
We have mildew in the rubber gasket behind the front door
    Top Expert:
  • Bosch Master
  • 12,153 Answers
Use a good mildew cleaner on gasket the gasket gets wet from when clothes are taken out and drip on gasket mildew grows on damp/warm surfaces
Posted on Sep 26, 2009
How do I get the mildew out from behind the rubber gasket in front of the front load clothes washer?
Mix bleach in water and use a brush or sponge to apply. Let it stand for a while rinse, repeat. Leve door open for a while after treatment. Check periodicaly for debris.
Feb 27, 2015 | Washing Machines
Collection of what appears to be mold on the door gasket, and a strong moldy smell inside the washer.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2010 | Maytag EPIC MFW9700S Front Load Washer
Extreme mold on the gasket. How do I remove the mold and odor?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!@
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Very unpleasant odor in LG front-loading washing machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@!!
Jan 27, 2010 | LG WM-2277HW Front Load Washer
Hi--I love my Whirlpool Duet washer, but how do I clean the door gasket and get rid of the mildew and mildew odor?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((())))
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have an Affinity Front loading washer model #ATF80000FG1. It has a sour mildewy smell to it when I open the door. The clothes come out fine but the odor is overpowering! Any ideas on how to get rid of...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 09, 2009 | Frigidaire Affinity ATF7000E Front Load...
Odor in kenmore front loading washer
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Jul 12, 2009 | Kenmore HE2 Plus Front Load Washer
Mildew on rubber gasket around door.
This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
Mar 18, 2009 | LG WM-2277HW Front Load Washer
Replacing the rubber gasket on Kenmore elite HE 3t
probably some rubberize installation are screw to the case or body/ you only need pollout are screw driver philips or flat .
Jan 01, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
428 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
