Question about RCA 27F530T 27" TV
Length to long
My screen size is to long...Its been that way ever since i bought it...how can i make the length shorter to read things at the bottom of screen?...
  • Akirashino Feb 05, 2009
    Size is off on the tv cuts off about a inch around the whole border
It takes an adjustment inside. If you're not affraid to take it apart I'll try to talk you through it. Write me at skipofsaturn@yahoo.com
Posted on Dec 18, 2007
Size of drive belt for HU700F walk-behind mower
belt lengths are printed on the back of the belt
so if it reads as an example 645 that will be the length so if you want one that is 1" shorter then the belt reading will be 644
if it is in mm the 1" shorter will be 25 mm shorter than the printed number
Sep 01, 2016 | Husqvarna HU700FH 22-in Self-Propelled...
I need to find out how to set up my machine for polyester/spandex material.
For spandex you will probably want to use a size 70 needle for stretch fabric. You should be able to leave your tension settings on standard tension but may need to go for a slightly shorter stitch length.
try stitch length of 2.5 or 3
tension of 3.5
check your bobbin tension, to do this thread the bobbin and suspend it in the air holding the thread. If the bobbin falls to the floor the tension is too loose. If the bobbin hangs in the air and you give a gentle tug on the string the bobbin should slide along the thread an inch or so. If it doesn't budge it's too tight.
When you say the thread is not the same on top as the bottom do you mean you are using different threads or that the stitches are coming out different on the top to the bottom of the fabric?
Mar 28, 2013 | Bernina Activa 140
How do I know what size figure skating blade I need to fit my figure skating boot?
When you compare the different lengths of a men's size 9 skate from different manufacturers you'll see a difference in length. Consult a sizing chart to help you determine what sizes to try on first. Usually, it measures like 10.94 inches long, a Bauer size 9 measures 10.9 inches long and a Remz size 9 measures 11.2 inches long.
Better Try on roller skates from several different manufacturers to ensure the best.
Jan 13, 2013 | Sport & Outdoor - Others
Stanton str8-20 belt size???
HI,
If you are unable to find your turntable measure the nearest length, if you are unable to find the exact length (as belts stretch slightly with use and age) choose the nearest shorter length. To check drive belt length for most type full platter decks remove mat and lift platter off center spindle (remove circlip if fitted), turn platter over and measure the circumference of the drive hub and deduct 5-10mm to determine correct length and tension
OK
Dec 11, 2012 | Audio Players & Recorders
I want to know what sizes is the frame of the versace VE 4157, as in the outer edges of the frame horizontally, i reference whit the width of the face,
Frame Size: 65MM 17MM 125MM
Typically there will be three standard numbers imprinted on one of the temples or the bridge, indicating respectively the sizes of three frame parts. All sizes are marked in millimeter.
1. Lens size: The first number 65 represents the lens size, which is also called eye size or lens width. Lens width is the most exact name of this size, describing precisely the distance between the vertical sides of a rectangle containing the lens shape. It is important to differentiate it from lens height. A large lens for a big guy usually has big sizes at both dimensions.
2. Bridge length: The second number 17 represents the bridge size. Other sayings include bridge length and bridge width. In detail, it is the minimum horizontal distance between the nasal surfaces of the rims. This size varies only slightly because people's noses will hardly differ significantly. When the frame is sitting too high on the face, it is necessary to increase this bridge size. In opposite, a shorter bridge is needed when the frame sits too low on the face.
3. Arm length: The third number 1125 describes the length of an arm or temple. This is the whole length of a temple, consisting of the length to the bend and the length of the drop.
Jul 18, 2011 | Versace VE 4157 Sunglasses
I was looking to find eyepiece for the citiwell international orbitor 5500 telescope. we bought used one and it didn't come with one. Linda in Va.
There are a couple of standard sizes for eyepieces, 1 and 1/4 inches (outside diameter of the eyepiece barrel) being the most common. Measure the inside diameter of your eyepiece tube. You can find lots of them on eBay or Amazon if you search on "eyepiece 1.25". The other number quoted will be the focal length. Shorter focal lengths give greater magnification.
Nov 24, 2010 | Citiwell International Orbitor 5500...
I have a small size chevy blazer 1995 with 5.7 engine can i swpa the stock 4l60e trans with a 700r4 trans it is 4 wheel dr
Yes you can,They are the same thing,but different names,The 4l60e is electronically controlled though,and the 700r4 came in 4 different designs,(shorter or longer)so measure length before you start.
Jan 15, 2009 | 1995 Chevrolet S-10 CA Edition
Snowboard length fit
"Length is one of the most important characteristics of a Snowboard. The length of a Snowboard is measured from the tip of the nose to the end of the tail. The length is usually measured in centimeters and often abbreviated to just the last two digits. Board length varies from 100cm to 180cm. To find the appropriate length for you, start by comparing the board length to your height. Although there are no dead set Rules in Selecting Board Length, the following are several guidelines to get you started. When holding the board on its end: * Short board should reach somewhere between your collar bones and chin. Shorter boards are easier to maneuver, great to be trained on, and often preferred by riders who do a lot of Snowboarding Tricks, park and Pipe Riding. * Medium length should come up between your chin and eyebrows. This length is preferred by all around intermediate to advanced riders who ride a variety of terrain, including parks and steeps. * Long boards should go from your forehead to several inches over the top of your head. Long boards are used for high-speed carving, deep powder snow surface, and big mountain terrain. Choosing the suitable board length is not only influenced by your height but also by your weight. Keep in mind that a Snowboard acts like a leaf spring - it has no clue how tall the person standing on it is. However, it does know your weight. Based on your weight or body structure, the following will help you choose the Right Length of Snowboard: * Lighter people should have shorter, more flexible boards. This is because a lighter person on a longer board commonly has a hard time controlling the board and initiating turns. * For an averagely built person, the board length should reach somewhere between the chin and your nose. * Heavier people should have longer, less flexible boards. A short board isn't advisable for heavy riders because the board often have a tendency to ""wash out"" or perform poorly, especially at higher speeds. * Freestyle riding is often done with a shorter board to allow better maneuverability. * Freeriding, deep snow, and racing boards will be longer in size. * For riders who are into Backcountry Snowboarding, go longer for stability. You may also consider your aggressive or timid style. If you're the type of boarder who really attacks the hill, you'll want to increase the length of your Snowboard up to five centimeters from the average size. Then again, if your riding style is naturally slower in character, go down five centimeters. Still, keep in mind that one Snowboard doesn't do it all."
Dec 01, 2008 | All Star Forum Star Women's Snowboard
RCA 27F530T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
