Question about ASUS R2H Tablet PC
Laptop screen freezes
Whenever i plug in the charger of the laptop the screen freezes after 2-3 minutes
    Scholar:
  • 83 Answers
This cud be a hardware issue where your voltage controller chip has blown the solution to this problem would be to replace the motherboard in most cases... but if u know someone who can do a chip level servicing it might help to ask them to replace the blown chip...
Posted on Sep 02, 2010
How do i fix my proscan tablet that is stuck on android screen
Try a power reset by pressing the power button for 30 seconds with your device unplugged, then plug in your device and leave it on the charger for a few minutes, then press the power button again for 30 seconds while plugged in.
Sep 30, 2016 | Tablets & eReaders
After 4 months my Fusion tablet won't turn on??
To help you troubleshoot the issue, please follow the steps given below:
- If your device's battery is almost dead, you'll often see an empty battery indicator on the screen when you try to turn it ON. But if you let the battery completely die, your tablet won't respond at all when you press the Power button.
- To fix this problem, just plug your tablet into a wall charger and let it charge for 15 minutes.
- Now try to power it ON with the Power button, if the problem was caused by a dead battery, it should boot up normally.
- If it doesn't work at all, try plugging the device in with a different cable and charger. The charger or cable could be broken and preventing an otherwise-good device from charging.
- Your device may be powered ON and running but the screen won't turn on because the operating system is frozen and not responding to button presses.
- You'll need to perform a 'Hard Reset', also known as a 'Power Cycle', to fix these types of freezes.
- You'll need to long-press the 'Power button' of the tablet and hold it down for 'Thirty seconds' this will cut the power to your tablet and force it to boot back up, fixing any hard freezes.
Now check if your tablet works fine, if issue persists, please go to your device manufacturer website and see the instructions for performing factory reset or you can contact the manufacturer for further assistance.
GuruAid.com
Jun 02, 2016 | Tablets & eReaders
HOW DO I UNDER FREZZER MY KINDLE
Hold the power switch for 20 seconds. Slide the power switch and hold it in place for 20 to 30 seconds before releasing it.
  • You need to physically hold the power switch in its off position for this long. Doing so tells your device to "reboot," in essence, instead of merely shutting down.
  • The reboot screen should appear as soon as you release the power switch.
Give the Kindle time to reboot. The Kindle will reboot within a minute or two. Be patient and give your device ample time to finish its reset.
  • There is some possibility that the Kindle will freeze as it reboots. This may be the case if your Kindle stays frozen on the reboot screen for more than ten minutes.
Charge the Kindle. If the device freezes during the reboot or does not respond to the reset at all, plug the charger in and allow your Kindle to charge for 30 minutes or more.
  • Make sure that your Kindle has enough time to complete a full charge.
Hold the power switch down again. After you finish charging the Kindle, slide the power switch and hold it down for another 20 seconds.
  • The reboot screen should appear again. Give the device a minute or two to reboot before checking it again. This should complete the reset.
Jan 01, 2015 | Amazon Kindle 3G
My tablet started shutting down and restarting while I was using it. It eventually would do nothing but shut down and restart but only partial start up. It freezes at the Samsung screen and then re
got same problem on my alcatel android phone. it has somethiing to do with heat sensor. I install toogle notification and put battery temperature as notification bar icon. whenever I used the phone for heavy app or charge it with hi-amp charger until it get above 38 degree, it will keep restarting. if it happend, no choice except remove battery until it cool back down.
Nov 05, 2014 | Samsung Galaxy Tab 2
Nabi 2 freezes when charging
I fit is a new tablet, I would take it (/send it ) back to supplier and complain and/or ask for a replacement.
If it is not new, then... hmmm.
Jan 11, 2014 | Nabi 2
ASUS T100 stuck at preparing automatic repair message will.not reboot
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode...
Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Nov 19, 2013 | ASUS Tablets & eReaders
Nabi will not charge .have new charger
Whenever you plug in your Nabi 2 tablet to charge, The tablet will boot up. Whenever tablet boots up, turn it off and leave it charging for a good 4 to 6 hours. That should charge it.
Aug 12, 2013 | Nabi 2
Im stuck on the recovery screen
unplug charger and remove main battery, press power button and hold for 30 seconds and release, let laptop sit for 5 minutes, reseat battery and plug in charger and press power, a long shot.
Mar 06, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Whenever I plug in my charger, the screen starts to flip, going upside down and sideways really fast, and the Q Menu pops up along with the onscreen keyboard.
it sounds like the charger is worn out, its output is noisy, if it works ok on battery then replace the charger, avoid using the bad charger it may damage your tablet.
Jan 26, 2011 | Compaq tc4400 Tablet PC
ASUS R2H Tablet PC Logo
148 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
