Question about Microsoft Xbox 360 Console
My xbox will turn on but when i turn to the channel on my tv it keeps saying 'no signal'
    Novelist:
  • 168 Answers
This is a common fault with the 360, it says that its a "general hardware failure" which could mean anything
really. In truth its the lead free solder that cracks with so much heat and as a result the Xbox 360 fails
causing the 3rrod (3 red rings of death) or e74 or even no sound but graphics or sound and no graphics just
like you are reporting.
Firstly get a spare av cable from someone else, try this, if that does the same then try a different scart
input on the tv. if all this fails you need to fix your machine as it WILL get worse
You will need to get a 3rrod repair kit or get someone to fix it for you, there are guides available on the
internet. Im in the middle of producing one right now that i will make available free of charge for all fixya
members.
Linda
www.xboxrepairkit.co.uk
Posted on Sep 28, 2009
Why is my Humax 4000 very slow, freezing and scrambled saying bad signal.
Check the signal level and quality. Reseat all aerial connections.
Jun 18, 2016 | Humax Televison & Video
I've a problem. When i switch on the tv. It says no signal. I've thought of turning the satellite but it keeps saying no signal and the signal quality stays at 4%. How to do? Configuration: technosat.
firstly the satellite dish antenna must be correctly aligned to satellite you want to receive.
technosat setup" initial setup" select the correct safelite ,once selected u should see signal strength /quality then tune the channels...auto works best, after this you can create your own favorite channel list
Nov 17, 2013 | Televison & Video
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
SD TECH
Sep 23, 2011 | RCA F25254GY 25" TV
My x box 360 keeps freezing ans saying you are disconnected from xbox live, what do i do ?
If your screen freezes when playing on Xbox LIVE, the problem may be related to your Internet connection. A weak wireless signal can cause poor Xbox LIVE performance. If you are using wireless connection:
1. Go to My Xbox and select System Setttings. 2. Select Network Settings. 3. Select Wired Connection or the name of your wireless network. 4. Select Test Xbox LIVE Connection.
If your wireless signal is only one or two bars, try improving your signal strength by following the suggestions below.
  • Move your router or gateway off the floor and away from walls and metal objects such as metal file cabinets).
  • Minimize obstructions along a straight-line path between your Xbox and your wireless router or gateway.
  • Shorten the distance between your console and your wireless router or gateway. Ideally, your network hardware should be near the center of your home.
  • Change the position of the antenna on your Xbox 360 Wireless Networking Adapter (external adapter only).
  • Turn off wireless devices. If your router uses the 2.4 GHz band, try turning off wireless devices, such as 2.4 GHz cordless telephones and Bluetooth devices.
  • Try changing your wireless channel. Wireless routers and gateways can broadcast on different channels and one channel might be clearer than another. See your hardware documentation for help changing wireless channels.
  • Add a wireless repeater to extend your wireless network range. You can boost your signal strength by placing a wireless repeater halfway between your router or gateway and your console.
  • Add an Xbox 360 Wireless N Networking Adapter.
  • Switch wireless signal bands. If you have a dual-band router and an external wireless adapter, try switching the router to a wireless protocol that transmits on the 5 GHz band (wireless protocol A or N). Please see your hardware documentation for help with changing the wireless protocol.
  • Switch to a cable.
Apr 05, 2011 | Video Game Consoles & Games
My 42" Vizio TV turns on and says No Signal, then
push INPUT on remote, select the input source you want, keep changing channel to find a exist channel.
Mar 25, 2011 | Vizio 42 in. LCD TV
Why does my xbox 360 make a loud noise when turned
try putting it into your TV if you have inputs and if you dont have any on your TV try a VHS player and put them in and scroll down to the channel L2 it will say that on the top right corner of the screen
Jul 29, 2009 | Microsoft Xbox 360 Console
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
Nov 24, 2008 | Insignia Digital-to-Analog Converter for...
Converter box
You'll need to keep your TV on channel 3 or 4 depending on what channel you set the converter box. All your channel changing will be done through the converter using its remote control after that. If you change channels on the TV itself and go off channel 3 or 4, the TV will not get a signal and will show you that "no signal" message.
Nov 24, 2008 | Sanyo AVM-3259S TV
Microsoft Xbox 360 Console Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
