When I opt for "print" on my Canon Pixma MP800 0n my MacBook, it automatically prints in colour. I would like to have the default setting as "Auto-sheet feeder" and "greyscale" printing, but cannot achieve this through "System Preferences". How do I change the setting, please?
  • 6 more comments
  • Colin Hill Sep 26, 2009
    At the moment all I am getting is "Error: webpage not found". In any event, I can see no pop-up button under "Print" on my Mac. Help!!!
    When I double-click the printer icon, all I get is technical details of previous print jobs, so that I am stalled at that point. My expertise is such that I don't have a clue as to whether or not I'm using leopard!
    When I ask my Mac-OS-X to print, it always prints in colour, whereas I mostly want to print in grayscale, but can't find out how to make grayscale the default using System Preferences. What should I do?
  • Colin Hill Sep 27, 2009
    I followed your instructions, but when I reached the point where you advised me to press the "menu" button, I could not find any such button anywhere: or am I just being a bit computer-illiterate?
    Very limited computer literacy, so please don't get too technical with me. In a nutshell, I need to find out to set my Canon Pixma MP800 to a default setting of grayscale printing on my MacBook OS-X, instead of colour each time, but seem to get nowhere using system preferences.
    I do have printer and fax in preferences, but feel I have exhausted every avenue for trying to alter settings, without any success.
    Trying to alter printer (Canon Pixma MP800) settings on my MacBook OS-X, having been referred to system preferences (contains printer and fax, but no facility for altering default settings), was also advised to select DL Envelope as default Paper Size, but to date none of the solutions has worked (including one suggestion that, after setting DL Envelope, I should press the Menu button, but could not find any such button. Must stress that I am no more than computer semi-literate, so keep it simple, please.
    Brilliant, thank you very much! Got there at last! Sometimes it pays to be a very stubborn Scot!
    Thanks again.
    Will this be my default setting from now, and would I simply need to follow the same steps to achieve a colour printing from time to time?
    Kind regards,
    Colin Hill
    President:
  • 3,278 Answers
Hi, Colin.
1. Select File > Print
2. Next to the name of your printer should be a little arrow. Click on the arrow to expand the print selection box.
3. Midway down is a selection box which defaults to "Safari". Click on this and select "Paper Type/Quality". Change your settings.
Next time, select print but try pulling down the "Preset" menu within Print, then select "Last used settings" which should match what you did previously.
"Preset" will then be set to "Last used settings" even after you close and re-open the application. That should change the Default.
Hope this helps.
Posted on Sep 27, 2009
  • 855 Answers
Go to your printer setup and adjust settings there. You are right it should also be under preferences that I don't know why it's not there. But you should be able to set it up in printer setup. Good Luck!!
  • 615 Answers
If you cannot use the system default and that by going to your printer file on the computer and select preference and change the setting then you can use printer driver settings within the printer. As it controls also the PPM print speeds which based on the highest speed printer driver mode. Photo print speed is based on the default mode driver setting using Canon Photo Paper plus Glossy paper. Print speed will vary depending on system configuration, interface, software, document complexity, print mode, page coverage; type of paper used and does not take into account data processing time on host computer. CPM copy speeds are based on fast-mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies. Addition to that you can change resolutions as it may vary based on printer driver settings. Color ink droplets can be placed with a horizontal pitch of 1/9600 inch at minimum...if you need step by step instructions of how to do that please let me know. Please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
Posted on Sep 26, 2009
  • Norman Al-Anbar Sep 26, 2009
    1. Click System Preferences
    2. Click Print & Fax
    3. Select your Canon PIXMA printer as the default printer
    4. Select DL Envelope for Default Paper Size in Page Setup…
    Save Setting
    Use 'Save setting' to retain paper size and media type settings suitable for the Auto Sheet Feeder (ASF) or the paper cassette. Ensure the size and media type are properly selected prior to saving the setting.
    1. Press the
    button.
    2. Use the cursor button to select 'Maintenance / settings' and press the button.
    3. Use the cursor button to select 'Device settings', and press the button.
    4. Use the cursor button to select 'Save settings', then press the button.
    5. At the Save current settings windows, press up or down cursor button to select 'Yes', then press the button.
    6. Press button to return to standby mode.
    Let me know. Please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
    President:
  • 2,923 Answers
Check the link below and you will see the pictured instruction on how to modify the printer settings. You will see the instruction on how to print in greyscale:
http://macmastersoftware.wordpress.com/2008/02/03/printing-grayscale-in-mac-os-x/
Have a great day!
  • Melvin Ramos
    Melvin Ramos Sep 26, 2009
    It seems that you Mac does not redirect you to the link that I have provided. Please try the steps below:
    1. Click the Apple Menu > System Preferences > Printers.
    2. Double-click the Canon Pixma MP800 printer icon
    3. Click on "File" (that's on the upper-left near the Apple icon)
    4. Select Print > Click the pop up button and select Quality and Media.
    (in Mac os x tiger select Colorsync and after that select Gray Tone)
    5.
    Check the Grayscale Printing checkbox.
    6.
    Press the Print button.
    By the way, are you running Mac Tiger or Leopard or Snow Leopard. Follow the steps that's provided and you should be able to print in Gray Scale. If the buttons on the printer properties are not responding in order for you to modify
    the settings, then you may want to verify it with Apple Store Tech Support.
    Let me know if the instructions helps you.
    Thank you!
How do I simply print single page on screen. currently when I press print all pages concerned are printed in reverse order.
Go into the computer's Control Panel. Find your printer (may be under Device Manager) and change the default settings.
Mar 17, 2016 | Canon PIXMA MG4250 Inkjet Multifunction...
I have a MP280 printer/scanner/copier that prints my photos out to dark, when it is on the computer it is pefect colour
Open the printer driver setup window
Select the manual color adjustment (or if already in manual and it had initially been printing fine, you may opt to select Auto)
On the Main tab, select Manual for Color/Intensity, and click Set....
The Manual Color Adjustment dialog box opens.
Specify the brightness
Select Light, Normal, or Dark for Brightness, and click OK.
The current settings are displayed in the settings preview on the left side of the printer driver.
Complete the setup
Click OK on the Main tab.
When you execute print, the data is printed at the specified brightness.
May 16, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
Canon MX-310 printer: How to remove double-sided printing option?
Duplex printing is set in the print dialgue box. You may have set a profile where duplex printing is automatic and the computer is defaulting to that setting. Make sure it says "Standard" in the print dialogue box.
May 02, 2011 | Canon PIXMA MX310 All-In-One Printer
Just set up cannon PIXMA MX870 printer. Cannot get it to print from wireless connection. In my printer box it says the printer is offline. It will print when I connect the printer with a cable. I use a...
I had the same problem - my printer showed that wireless LAN was enabled & my mac showed the printer but said it was offline. I went to preferences, print & fax, hit the + key to add a printer, added the canon printer again, set that printer as my default, did a print command from Word & that created a queue in the new default printer ... and it printed. Deleted the first Canon printer that was "offline." Oh, and I'm not sure if it made a difference, but before what I just described, I checked for software updates after the printer CD install process & uploaded one update.
Jan 27, 2011 | Canon PIXMA MX870 Wireless Office...
I can't get my printer to print in colour. I
Printing Properties
Advanced
Printing Default
Gray scale printing
Jul 11, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My Pixma iP1500 will not print in colour even with a brand new ink cartridge and after deep cleaning. Black printing isperfect.
go to controlpanel>printer> ur printer driver..
check the settings..
if u r unknown of the settings restore default if u r printing from ms word see the print options and in advanced there will b the link to print color. check the appropriate one .
there u go. now print as much as u want
Mar 10, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Printing shcrunk
Check the default printing settings for the printer under printer properties. It sounds like the size is being sent from the macbook to the printer.
Apr 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Canon MP450 doesnt print from my computer
Check your print defaults and make sure that the Canon MP450 is set up to be the default printer. If it still continues to be a problem than check the print cable by changing it out.
Feb 17, 2009 | Canon Pixma MP500 All-In-One InkJet...
The printer suddenly refuses to print black but will print colour
try to set it in the default printer settings. it will go back to the original set up
Nov 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Photos printing yellow tinted
Please try this: go to Control Panel, then Printers. Right click on your printer and choose Properties. There should be a Colour Management tab. Click on this. There should be two options: Automatic or Manual. If the Manual radio button is already selected, click the Automatic radio button. The best default Colour Profile to suit your printer should then automatically be chosen.
Jan 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
107 people viewed this question
jasbo
jasbo
