Question about Volkswagen Golf V Vw Scale Diecast Model
Same as above
I hawe the same problem only my car doesn cuts off yet but its near doing that. when the car is runing ewerything is ok but when it stops and runing on neautral gear the revs goes to about 5 or 6 thousans and u can hear that engeen doesn run wery well. when i just start the car in the morning its ok for about 2 min th revs is on 8000 but affter that as above.im driving vw 5 1.6 FSI .sorry for english and looking to hear back from someone what couses this problem
SOURCE: runing rough for 1 min. after start cold engine
95 vw golf 2.0l. engine blue smoke
Posted on Nov 01, 2008
  • 192 Answers
SOURCE: vw passat will not run
*Assuming everything ran fine prior to running out of petrol*, the most likely cause is air in your fuel lines or fuel injectors.
For a Volkswagen, the most sure fix is to have a Volkswagen mechanic inspect and maybe clean and prime your injectors. If you are handy enough, you could possibly do this yourself, but it can be quite hard.
Also, there are some additives that claim to be able to fix this in a bottle, but there efficacy is marginal at best.
Last, this problem can sometimes work itself out, though the process of waiting for the bubbles to clear (you may have to endure many quits by your engine) can be more than frustrating.
I hope this helps.
Posted on Jul 28, 2009
  • 2002 Answers
SOURCE: VW Golf 5 FSI 2.0 - Misfires or will not start at
A quick effective inexpensive fix would be to spray your electrical system with a can of Rust Check. While it is a rust proofing it is also waterproof. If you get the stuff in the green can, it is thicker and doesn't wear off near as quick. Hope thishelps.
Posted on Oct 12, 2009
SOURCE: I have a vw golf mk 5 2.0 sdi, when engin starts,
Check the VAG code. I had the same problem with my MK V 1.4 FSI. Let me guess when you rev it, it dusnt shake anymore?
It might be one of your cylinders are misfiring. And this might be faults with spark plugs, coil pack or the injector. You'll be lucky if it is the first two as they aren't much expensive to repair. It will cost you if it is the injectors.
Posted on Mar 02, 2010
SOURCE: my 2002 beetle keeps acting like it wants to cut
Just had mine fixed this weekend. Have someone put a computer test on it (forget whats its called but they attach it under the steering.) They found a bad coil, so changing the spark plugs and one coil fixed it. cost 120.00 private party. but its working and yes my signal that means catalytic converter was on also. Thats what can be damaged if you keep driving it. Hope that helped you .
Posted on Mar 08, 2010
Why the car cranks up and stay runing for 2 min then it will cut offwhat could that be
when it stops check for a good spark at the plugs if ok check fuel pressure and flow replace fuel filter if pressure ok.
Aug 15, 2014 | 1997 Pontiac Grand Am
Engine cut out no eccelertor
.dear first . you need to make sure ignition coil on spark plug are ok
second fuel pump . third you should keep engine runing without accelerator for a while then you can accelerated .
Mar 26, 2014 | 2005 Skoda Fabia 1.2
Chainsaw will not stay runing
hello sir,, now there are two types of carb.adjustment screw covers,the old one where there are plastic over the screws,simple remove the plastic covers with a pair of needle nose pliers or cutting off,,,second are the new ones that are above the adjustment screws,which you have to take your drummel tool with the cutting blade and cut slots in the screws, after you get this done it is important to count the number of rotations in until stops make note how many. because you are going to reset the same way.now remove the screws,put to the side when you get ready to put screws in put in all the way than back out as many turns that you noted, now that is factory set there should only be a small adjustment to do. the rule of thumb is turn both out 1 1/4 turn and adjust in until saw runs smooth and idles ok, it is hard to adjust the top speed when saw is running wide open,let saw idle when adjusting top speed is easier that way, when you go to cut wood you may have to readjust top speed, the above does apply some what if you are not using fresh gas mix and dumped out the old fuel and starting with fresh,and a new plug CJ8Y,and as you know the saw has to breath in and out by this i mean a clean air filter,make sure the small screen on the muffler is not cloged,this will keep saw from running at peak speed and sawing wood, ok i have ran across a few saws to where the small screen in the muffler is cloged so the saw would idle but not run at high rpm's,if you do and check all of the above your saw should run,oh btw check compression should be above 60 to 160 lbs, hope this helps,any comments welcome,thank you. ~~
Feb 19, 2012 | Garden
I hawe 97 chevi venture cooling fans wont come on when carr iz runing
Either the fan motors are bad or the temp relay located on the top of the engin block may be bad and worse case is the computer may not be sending a signal. You can also check the two relays located in the fuse block under the hood.
May 01, 2011 | 1997 Chevrolet Venture
Additional information on Suzuki Was runing fine
this is probably the fuel pump problem ,check fixing wires and try again,try to hear if the pump works or not.
Mar 30, 2011 | 2000 Suzuki Grand Vitara
Haw i can take the video wit manual
Try to use the channel buttons and go below channel 2 or above channel 125,
You might find the video input there. Hope this help.
P.S please do not rate this answer(unless it helps) as it is only a suggestion
Dec 08, 2009 | Emerson EWF2004 20" TV
Hot coolant not getting to Heater Core.
some 88 chevy hawe valve on top of intacke manifeld and operate on vacum shot of valve for heat,aplay vakum on and se if working.yu hawe to tach both hoses wat going in to heater box mast be hot ven engine runing,if are not hot problem heater core
Mar 12, 2009 | 1988 Chevrolet K1500
Volkswagen Golf V Vw Scale Diecast Model Logo
54 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Bogdan Odwazny
Bogdan Odwazny
JonSnell Electronic
JonSnell Electronic
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
