Question about Bose Cinemate Digital Home Theater System Speaker
There is no headphone plugged in the tv speakers wont work
Even with tv speakers turned on the tv indicteds that there are headphones plugged in and the speakers are not working.
  • 6,831 Answers
Hello
I had the same problem with my computer, where there was no sound because it showed that there was earphones plugged in.
The problem was the the earphone unit on my front USB pannel was a bit worn out, so it shoted out. I just took it to a repair shop and an hour later all was fixed up perfectly for very cheap.You should maybe try it. Please rate if this worked for you.
Best regards
Posted on Sep 26, 2009
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
Trying to get new headphones to cancel speakers on tv
What kind of headphones and TV are you trying to make work as an combined pair? It sounds to me as though you have your head phones plugged into the speaker location on the TV which could be a small hole that shows a pic of speakers. Look on the TV for an 'mic' or 'pic of headphones' holes. If there is an plug in hole with either it states mic or shows a pic of headphones plug the headphones into that hole instead of where you have them plugged into now.
Another suggestion is to use MDI cords in which you may already be using aka white, red, yellow colored plugs. If those plugs are assembled in the slots incorrect that also could be the reason as to why the headphones turn down when you turn the volume to the TV down; which also would influence the TV volume its self to also disengage to go either louder or quieter. MDI cords should be plugged in the following pattern to be categorized as the following with each color following the next color; yellow, white, red. Now if you are using MDI cords presently do you have them plugged in front or back of the TV?
If the TV has hole ports in both front and back for MDI cords then reverse your plug ins. Example: If you have them plugged in the front instead switch all three to the back of the TV or vise versa.
Also another thing; since you are wanting to use headphones for your TV speakers instead of the TV speakers themselves usually plugging headphones in are controlled by TV volume buttons; however I am assuming that you are trying to state that when you plug headphones into the TV you still hear the volume in your ears and anyone in the TV room is also still hearing the TV even though headphones are plugged in, am I right?
With you wanting to cancel the speakers on the TV out only attempted to use TV volume for speakers and without it working means you have the MDI cord plugged into the audio which would cause the TV to power the volume for the headphones anyways. May I ask this; since I am a bit confused, alright are you wishing for the headphones to be able to be loud enough so the TV only powers them for volume when you use the TV?
I know that headphones being plugged into an TV should only keep their volume within the ear buds. Therefore I have never heard of headphones being able to be loud enough to power out room sound. Instead they power internal volume which would be within your ears. Headphones were meant to keep noise and volume from surrounding a room to block room noise out and to keep the sound for your/ an own persons only listening capability. So because of this I am confused as to how ear phones would have the ability to sound the room with audio.
I can understand that if what you are trying to say is that the speakers on the TV still output volume even with head phones plugged in which would be an issue, since head phones are to capture the volume and noise from the unit in which plays aloud- to actually silence it instead- for the individual whom requires or presumes to have themselves to be the only listener.
Jan 02, 2014 | JVC 900MHz Wireless Stereo Headphones with...
Where do you plug in the headphones?
You can plug in headphones but you need an adapter. Also, not all headphones will work well with this TV. You should get headphones with in-line volume control. Then connect the headphone 3.5 mm M to a 3.5 mm F to dual RCA (1/4") M/M adapter. An example is http://www.sears.com/shc/s/p_10153_12605_05711931000P?sid=IDx01192011x000001&srccode=cii_17588969&cpncode=22-191604286-2 .
Then use the TV audio menu to turn off the TV speakers and enable the external speakers. Note the TV volume control will not effect the headphone volume.
I hope this helps.
Dec 23, 2011 | Mitsubishi WS-48311 48" Rear Projection...
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
My 26 inch Panasonic Viera TV has what looks like a headphone jack on the side of it but when I plug headphones in the sound still comes through the TV speakers. How do I get the headphones to work?
Check you USER MANUAL to make sure it is actually a headphone OUTPUT jack and not a digital INPUT jack.
If your tv does not have a headphone output jack you can always get an adapter that plugs into the red and white AUDIO OUT jacks in the back.
If you want to turn off your tv's speakers, go to the MENU.
Then go to AUDIO then select SPEAKERS OFF.
Good luck and please post back with how you make out.
Jan 24, 2011 | Panasonic Televison & Video
Headphone out jack is really quiet.
If you're trying to plug the speakers into the headphone connector that will happen.
Headphones are having a high impedance and those loudspeakers a low impedance.
That's why your volume is down. It stresses your audio-amplifier and even blow your finals.
Cheers,
Gerard
Jan 30, 2009 | Televison & Video
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Dec 26, 2008 | Televison & Video
Bose Cinemate Digital Home Theater System Speaker Logo
114 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
