Question about HP Compaq nx6110 PC Laptop
Hp hanging when pressed down works well
  • 484 Answers
While I am not certain to what you are referring, it sounds like you are saying the laptop itself doesn't work unless you press down on it.
This sounds as if there is a loose cable inside somewhere.
Go to the HP web site and search for a schematic for this model of laptop. It will show you how to open the case without destroying it.
Then look carefully for a loose wire or cable and reattach it.
Good luck,
-a.
Posted on Apr 19, 2010
    Problem Solver:
  • 12 Answers
Some of the connections migh be loose or contacts are loose .Pl check if all the screws are properly placed & fitted , if you check & make it ok your laptop will work fine
Posted on Oct 02, 2009
I have hp nc6220, if often hangs and is always unpredictable, but when i press its touchpad from downward and keep it pressed it works, when i release that it hangs again
I had this problem (hanging on the screen with F10 = ROM based setup) for a while on my HP nc6220 laptop. Was taking several attempts to boot. Replaced the hard drive. Ran virus and malware detection, all clean. Stumbled on to the posting where someone wrote about applying pressure by the touch pad seemed to help. It did. Then the problem gradually got worse. Thought maybe there was something loose. Downloaded the disassembly procedure from hp.com. I found the 2 ground contacts under the touch pad had oxidation on them. Cleaned them with a pencil eraser. Reassembled the laptop and have not hung once. Everything runs faster as well. This is not for the novice, but someone with a little experience should be able to get through the process. Hope this helps someone.
Dec 24, 2010 | HP Compaq nc6220 Notebook
How do i cold reset a HP CM6040F MFP COLOR LASER PRINTER It doesnt complete the initilization process... keeps hanging on step 6
restart the printer hold down 6 when backlight illuminateshold till all three lights turn on,relese 6 keythen press 3 or 9 to scrool
press 6 to select the optionu want then enter cold reset starts......
Jul 14, 2010 | HP LaserJet 4730 MFP Printer
HP COMPAQ NX6110 LAPTOP HANGS WHEN BOOTING, BUT WHEN PRESSED AROUND THE MOUSE PAD OR HARD DISK AREA IT WORKS , BUT HANGS AGAIN LATER
It seems that the hard drive or the memory module is not seated properly and hence after pressing on the area below keyboard it gets released.
You can try following things.
Remove and reseat the Hard drive.
And remove and reseat the Memory.
Try to power on the laptop again.
If is getting hang again then you may need to do the HDD self test and memory test built into BIOS.
May 26, 2010 | HP Compaq nx6110 PC Laptop
After shutting down svchost.exe appeared.and hang itself.
If its not doing this all the time, and the laptop is just stuck on, press and hold the power button down until the laptop turns off.
If its a reoccurring problem, run a check disk.
if it still does it, disconnect one piece of external hardware one at a time until the scvhost.exe doesn't hang on shutdown, and you have found the culprit.
Jan 21, 2010 | HP 510 Notebook
HP Pavilion dv6700 Entertainment wont boot
1. Power on (NO Disc.)
2. Press Pause
3. Enter 314159(with remote)
Display will show "FF"
4. Quickly press "0" (for all region)
5. Press pause
6. Power off and powere on after 20 secs.
Dec 09, 2009 | HP Pavilion DV6700T Notebook
Laptop keeps hanging
TRY TO BACK THE OLD ONE IF IT IS OK THE NEW ONE ARE NOT COMPATIBLE
Aug 18, 2009 | HP Compaq nx6110 PC Laptop
My laptop compacq nx6110 hang i hv to press the motherboard
this problem is hardware related, this problem caused by the chipset "intel 82801 fbm" . if you have an electronics experience,
remove the mother board,
find the chipset intel 82801 fbm
reflow the chipsett by "bga rework station" or "hot air blower"
then refix and check the system
Jul 04, 2009 | HP Compaq nx6110 PC Laptop
My hp p3005 laserjet it's hanging
This is a common problem with that model. It generally means that there is something going on with the formatter assembly. The easiest thing to try first is to remove any cards from the EIO slots
The next few steps will narrow down if the formatter is bad or the print engine itself.
First remove the right cover by sliding it towards the rear of the printer
Then stick something "non metallic" in the hole indicated to press the engine test button. This will tell you if print engine is working (a good thing!)
If you get a page to print out, that means there is something wrong with the formatter and you should have a service technician replace it.
If you don't see a page, be sure you are pressing it in all the way and if there is still nothing, it's time to have a technician come take a look at it.
May 02, 2009 | HP LaserJet P3005n Printer
By pressing motherboard the hanging system go further
Your problem is with your motherboard. I'm afraid you'll have to get a replacement
Apr 06, 2009 | HP Compaq nx6110 PC Laptop
HP Compaq nx6110 PC Laptop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
