Question about Garden
18V Ryobi battery charger (BC-1815S) isn't charging
18V Ryobi battery charger (BC-1815S) isn't showing red or green light when battery is inserted and charger is plugged in. I don't think the battery is charging properly. It's a new battery and a new charger. There is a slight hum from the charger, but no light is showing.
5 Suggested Answers
connertamago
  • 37 Answers
SOURCE: Ryobi 18v One+ battery won't hold a charge. I have
if it's both of them then i am thinking you have a faulty charger. i have seen mine do that, i got a new charger and it worked properly.
Posted on Jun 01, 2009
carlsbiz
  • 1124 Answers
SOURCE: light on ryobi 18v charger
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Posted on Jul 31, 2009
  • 340 Answers
SOURCE: When I put the 18V battery in the charger, the
i always thoiught that when you light is green it is fully charges yellow is weak and red is dead
maybe you have it reversed check it again also make sure that (altho hard to do) the battery is in right
Posted on Mar 08, 2010
  • 35 Answers
SOURCE: Dear Sir/Madam, I would like to
you shouldnt have a problem with it, but you can also go to their webpage and research there if there is any farther doubt.
Posted on Apr 22, 2011
Testimonial: "Prompt answer and solution. Thanks"
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Mar 15, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
I have a new Ryobi 18V Drill which came in a package from Screfix with two batteries. I charged one of the batteries to start with and when the green light came on I used it and immediately charged the...
Take it back to the store and tell them it is no good, and get a new pair of batteries, take the charger too. I had the same thing, brand new batteries, gone in weeks, they replaced them, no problem.
Feb 21, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Either the battery is hot from use or has been in the sun, let it cool down, then try again.
Nov 16, 2008 | Ryobi Multi-Volt Battery Charger
Garden Logo
797 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
