Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Lacie Hard Drive won't connect via USB anymore
My external HD powers up normally, green light, normal sound etc; But when i plug the USB cord into my PC nothing happens. Normally it would give you the standard PC window thing, but now it seems like the USB connection between my PC and the HD is not working. I tried using another cable; other USB ports; checked the USB ports; and other PC and that didnt help; I'm afraid my HD's USB port is broken? I did drop it but it a while back but it was not on at the time, and the HD seems to spin normally; Any idea where I could get a new USB interface for my HD if that is indeed the problem? Please help...
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
DO NOT PLACE IN A FREEZER !
THIS IS VERY OLD ADVICE FOR VERY OLD TYPES OF HARD DRIVES THAT ARE NO LONGER EVEN MADE. A FREEZER CAN CAUSE MORE DAMAGE.
Posted on Sep 26, 2009
  • 284 Answers
You could find a usb drive case on ebay. You just need to make sure you get one with an internal interface that matches your hard disk.
You may be able to install the hard disk directly in your pc.
Again you will need a little bit of luck as it will depend on what inferfaces your PC has available.
If your external disk uses a IDE interface make sure you get the master slave jumpers correct. It would be best to try it as the only interface connected to the port so you may have to temporarily disconnect your CD drive.
If you dropped it even with it turned off somthing may have been broken.
If it stopped working straight after you dropped it then there is probalby not much hope for it.
If you have data on there that you really need to retrieve you could take it to a data extraction expert but they are really expensive.
One trick I have herd about is putting it in the fridge for a couple of hours then connecting it to your pc. You might get a few minutes to access your data before it warms back up. This technique sometimes works for drives that are nearly worn out. Not for drop victiums but you never know your luck :)
Hope this hepls
  • 332 Answers
The problem could be worse than that if you had dropped the external HD. It could either be from the USB port or from the HD itself. Try taking it to a nearby hardware store and give them in details what happened.
Regards
    Sergeant:
  • 191 Answers
If you need DESPERATELY to access your drive you always can crack-open [gently of course] case of your drive [inside is normal pc internal hd], disconnect it from there and put into some other drive case or insert directly to pc, cos you can't replace just usb ports and this is always cheaper than giving the drive to data recovery company...
  • 615 Answers
Do you have only one usb port? Get usb port that connect to your computer and allow you 4 more as far as the device you need to connect, try first deleting the old driver and that in device manager and system then shutdown the system and start again (you must be admin) then connect your device and the computer will read the driver for it again.
p.s. you may need to download new driver first, let you know. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
Power Light comes on, no function what so ever
Check to make sure that the FireWire or USB cables are
correctly attached and firmly seated in both the drive and
computer's FireWire or USB ports. Disconnect them, wait 30
seconds, and reconnect them. If the drive is still not
recognized, restart your computer and try again. If they are
correctly connected and your drive still does not power on,
trying using the optional power sharing cable, described in
section 2.3 Connecting the Optional Power Supply of the LaCie Mobile Hard Drive User Manual.
Feb 17, 2013 | LaCie Computers & Internet
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie not working
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Nov 02, 2008 | LaCie F.A. Porsche (301177) Hard Drive
Fried HD?
Yep, it's probably fried, a little too much juice went in.
While the drive itself might be ok, the external casing is another story.
Try opening the case and removing the HD and plugging that in on your PC directly as a slave drive.
Sep 28, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500GB P3 got the clicking sickness
There are companies that can recover the date from the disk of a failed hard drive, check online, It is expensive.
Apr 20, 2017 | LaCie 500GB P3 HD USB 2.0 7200RPM 8M 500...
Lacie hard drive nonfunctional
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Mar 02, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 80GB
Is this a USB based HDD? It may not be getting enough power.
I have a LaCie 100GB HDD that has 2 USB connectors. One is for data and yes, the other is for power. The 2nd connector is needed because some USB ports do not provide enough power by themselves. I have to use both connectors when I plug my drive into a USB 1.1 port. USB 2.0 ports seem to have enough power.
Try connecting your drive into a USB 2.0 port. If you have 2 connectors, try plugging both in. If this doesn't work you may need a replacement power supply or you may need to replace the HDD.
Binary Bob
Nov 25, 2007 | LaCie (301074) 80 GB Hard Drive
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
2,016 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
