Question about Whirlpool LER5636P Electric Dryer
Dryer will not start...Dryer has power, belt is not borken, no other visible defects seen.
  • Whirlpool Master
  • 1,606 Answers
You have a bad thermal fuse . A small white piece , with 2 wires going to it , located on the blower housing . It may be on the rear of the dryer (remove the back panel if panel is grey ), or on the housing behind the front panel . (have to raise the lid to remove the front panel ) . Without the model number , cant tell you exactly which location .
Posted on Sep 26, 2009
Kenmore 62922 electric dryer
follow this steps and fix it. God bless you
Thermal Fuse
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Enter your model number to see parts for your dryer.
Help me find my model number
Start Switch
The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Most door switches will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor
On most dryers the drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt
On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit
Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem
If the dryer won't start, check to make certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch
If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board
The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer
The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 01, 2013 | Dryers
Not working
Thermal Fuse
Start Switch
Door Switch
Drive Motor
Drive Belt
Belt Switch
Main Control Board
Timer
Jul 09, 2013 | Kenmore Elite Oasis 7808 Gas Dryer
When you hit any button it turns on and the next button shuts it off
Thermal Fuse
Start Switch
Door Switch
Drive Motor
Drive Belt
Belt Switch
Main Control Board
Timer
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Belt has borken
how to open a cabinet:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt diagrams:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 15, 2011 | Dryers
Drum does not turn. Cannot see belt (if this model uses one) anywhere upon opening top. Have not opened up further. This item is about ten years old. Weighing options of fixing or buying new machine.
the belt is borken and laying in bottom of dryer . they all use one . buy the belt and replace it its easy job and belt is only 15 to $20.00 .. clean out lint exc and lube things up /. probably get another 50,000 miles out of it . mm feed back pls .
Dec 22, 2009 | Dryers
Belt borken. Should I hear the motor spinning
Good day,
Yes the motor will run with or without the belt. The blower discharging air out of the back of will still work,
as well.
Dec 21, 2009 | Kenmore 62602 Electric Dryer
Dryer will not start...checked belt and is good...dryer does have power source but no other visible problems seen...mod#: LEQ8000JQ2...ser#: MM3713012...type: DWSR-ELE-2406028-CV54....Thanks
If the lid switch is defective, the washer will not function or work at all. It is located inside the washer main housing near the door frame. When you close the door, the switch is activated by an actuator. You have to raise or open the top or front panel of the machine to reach the switch. Replace if found defective.
Sep 26, 2009 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
