Question about HP Pavilion zd8000 Notebook
Our laptop does not run on battery power only. Even with a fully charged battery, the computer does not work.
  • 332 Answers
I've had that same problem with my Compaq Presario. You will need to change your battery, i.e. get a new battery and a new powerpack.
Regards.
Posted on Sep 26, 2009
Why is my laptop unable to run off battery power, even though battery shows fully charged and AC is unplugged
It's time for you to replace your battery.
how old is your laptop? and how do u use it - do u leave it plugged into the wall socket all the time? It's common for batteries to die out after a couple of years. however, if the computer overheats or if you leave it plugged in all the time, it's life cycle will decrease. Charge - discharge cycles. That's how you are suposed to do it.
Jul 17, 2014 | Lenovo IdeaPad U550 Notebook
Charging battery compaq presario c700
If you can reach inside the computer and rub the battery contacts gently to remove the corrosion ,which is invisible , this will help greatly. Sometimes even a new battery will suffer the same. Clean the battery contacts also turn off the laptop and charge it fully do this on a regular basis. Say once every 2 months
Nov 05, 2013 | Computers & Internet
Can not run netbook off battery even though battery shows fully charged' When charger is removed netboook will not turn on
Make sure the battery is fully inserted and clicks in to the netbook body. Your battery may also be showing that it's charged but is actually dead. Try a new battery and see if it solves your problem.
Jul 04, 2013 | Wolvol Mini NOTEBOOK COMPUTER Laptop...
When I turn on my laptop the power lights up and shuts off after a few seconds
either a bad battery, or charge port. even if the battery was fully charged it will still keep the light on, try this. plug it in, and power it on, then remove the battery completly, the computer should stay on, as its running off the plug power cord. if this port is a bad one the pc will shut off immeadatly. and if it stays running then it will be the battery.
Jan 06, 2011 | Gateway M-6843 Notebook
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Battery meter is low, even though computer is always plugged in
Hi, I recommend you to try refreshing your battery by doing this step for 3 -5 times 1.Make a fully charge it take around 10 Hours. 2.Unplug your adapter and use the battery until it fully finish.Off by itself. 3.Repeat step1-2 for 3-5 times and see it again
Oct 07, 2009 | Acer Aspire 6920 Notebook PC
The computer will only run from a fully charged battery.
friend
the problem clearly shows the fault is in the motherboard
thanks
Apr 10, 2009 | Toshiba Qosmio G35-AV650 Notebook
Dell inspiron b130 power problem
try running with battery out it should still work as long as it is pluged to a/c
Feb 18, 2009 | Dell Inspiron B130 Notebook
VAIO VGNTZ150N Laptop battery runs down when not in use
If the laptop is gone into a suspended mode it is still powered on but sleeping. This will continue to use power and will power down the battery over time.
You could enable hibernation which saves the current state of your pc so that when you activate it again it restores to your previous state of work. This will use close to no battery power to perform.
Apr 24, 2008 | Computers & Internet
HP Pavilion zd8000 Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
