Question about Canon Office Equipment & Supplies
I have a canon mp490 - Internal error code 5,202,54
I have a canon mp490 the printer & copier work fine but i can't scan, i purchase a new usb cable 2.0 but that hasn't fixed the problem. I have a Vista Operating system. This is the error that comes up.
SCANGEAR
Internal error occured
Scanner driver will be closed
Code: 5,202,54
I've tried scanning straight from the printer also and absolutely nothing happens except it keeps asking me to set the document on the platen glass.
The memory card parts works too
  • 9 Answers
SOURCE: Hardware Internal Fault
This looks like a hardware fault. I hope (by now) that you have got an RMA and had it replaced.
Posted on Oct 23, 2007
  • 111 Answers
SOURCE: Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
Check the lock switch and make sure it is unlocked. I think the lock switch is on the bottom...or it may be under the lid near one of the hinges. Flip it back and forth and leave it in the unlocked position.
If this doesn't work, then it will most likely need service. Contact Canon Tech Support.
Posted on May 09, 2008
  • 461 Answers
SOURCE: CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
Posted on Jan 10, 2009
SOURCE: Canon ScanGear CS driver error Code: 2,252,0 - Can't preview
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Posted on Apr 27, 2009
  • 70 Answers
SOURCE: Canon MP250 printer scanner in a canning mode
Go to Device Manager at USB Controllers and disable Standard Enhaced PCI to USB Host Controller. If you can't find exactly this, disable the one with the word Enhaced in it. Right click it then click disable.
Posted on Nov 29, 2009
Scanner not working
Hi loui,
i suggest you Go Visit Canon Scanner Video & fix Your Problem.
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 11, 2014 | Canon PIXMA Office Equipment & Supplies
SCAN GEAR INTERNAL ERROR CODE 5,202,54
This is a well known problem. Users have often asked Canon to fix it but the development team never provide a fix.
Feb 06, 2013 | Canon CanoScan LiDE100 Flatbed Scanner
Error 5,202,52 on scanner canon lide 110
TO ANYONE READING THIS...I nearly took a hammer and smashed my Canon LIDE 110 Scanner cause I was so mad that it gave me this stupid error (5,202,52) no matter where I was connecting it and I thought it was done...
THEN I just took another USB Cable (Like I have around 10 different USB Cables) ...AND IT WORKED! Try several USB cables before you give up on it...also don't start messing around with drivers and stuff, you could end up screwing up your system like I did...
I hope this helps someone out there in the future with error 5,202,52 or 5,202,54, etc.
Try at least 4-5 different USB cables before anything else..
(If you want to know, I successfully used the USB cable with one of the fat black circle things on it (I think its for power or something), not just a straight usb cable. It's still a 5 pin USB cable however (Regular USB on one side, small 5 pin connecter on the other side))
Jan 13, 2012 | Canon Office Equipment & Supplies
I have a canon mp250 the printer & copier work fine but i can't scan. This is the error that comes up. Internal error occured Scanner driver will be closed Code: 5,202,54 what should i have to...
ive been resolving that issue for almost 8 hours since last night.(that means i did not sleep) because i badly need to scan papers for my precentation today. finally it worked after unstalling all canon folders, then reinstall everything... hope this work with you
Aug 05, 2011 | Canon Office Equipment & Supplies
Internal error occured code: 5,202,52 after installing Canon CanoScan Lide 210
Perhaps you have forgotten to unplug the scanner before
scanning? That's what happened to me. I kept getting
different error codes, 5,202,63 or 5,202,52 or 5,202,54 and
also a message that the driver was not in the TWAIN folder.
According to the help file the problem might have been due
to my nfts file system. I also tried downloading various
new drivers. Nothing helped until I noticed that I had not
unplugged the scanner!
Apr 11, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
Scan gear internal error occured code: 5,202,52
Canon MP490 printer error code 5011
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints. that should solve it!!
Mar 22, 2011 | Canon MP490 InkJet Printer
CANON PIXMA MP490 ERROR CODE IS 5200 AFTER INSTALLING NEW BLK INK..........
canon mp490 error 5200 solution...... turn off printer,then hold reset button(the red 1 circle with triangle in middle) for 5 sec then whilst holding reset button turn power on let go of reset button then push reset button twice whilst still having hold of power button then release power button then push reset button 4 times and then power button twice hope it works it did for me carlos:)
Jul 30, 2010 | Canon PIXMA MP490 Inkjet Photo All-In-One...
ScanGear Internal Error Code:5,202,54
all i am getting is advertisements that can "fix" my computer at a price, everywhere says there is a driver out of date but nowhere tells u how to fix it
its a cannon mp250 throwing up error5,202,54 when trying to scan
Mar 07, 2010 | Canon Office Equipment & Supplies
Canon MP250 printer scanner in a canning mode shows error message code 5,202,54. It does not scan. It however prints files from my laptop alright.
Oct 22, 2009 | Canon Office Equipment & Supplies
2,835 people viewed this question
old marine
old marine
