Question about Lexmark X9350 All-In-One InkJet Printer
Check inside for printer obstruction . how do I open the case ?
  • 615 Answers
You do not need to open the case…what they meant that you may have paper jam and that get accessed from the front paper feeder or from un correct instillation of the inks and that by opening the door in front and replacing the ink again in the housing and closing the door good , let you know. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
Posted on Sep 26, 2009
2 Suggested Answers
  • 1550 Answers
SOURCE: the display screen tells me
This indicates that there is chance of paper jam on your printer . Remove the cover and remove any bit of paper and clean the roller with isopropyl alcohol and then put back cover and restart printer .
Hope this helps .
Posted on Dec 11, 2008
Hp officejet 4630 carriage jam
Check first:
Are you printing correctly? Are the papers in their correct position? Look the picture below, is it 100% identical to how your printer looks right now?
hp-officejet-4630-carriage-jam-g3kwcv4s0uxqjd0jsmqlsidv-5-0.png There are a few ways:
1. Open the cartridge access door and remove any obstruction in the movement of the cartridges.
2. Re-install cartridges.
3. Plug the printer electric source directly into the wall outlet.
4. Check the picture above and check your alignments again.
Jul 11, 2015 | HP Officejet 4630 e-All-in-One Printer
It shows "remove any obstruction
Open the printer cover and access the cartridge area. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip). If cartridge area clear from these, Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the cover and try to print again.
May 27, 2011 | Lexmark X4650 InkJet Printer
Error code5100
HI:
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or in my case popcorn. There was even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
Apr 20, 2011 | Canon PIXMA MP470 All-in-One Printer
Service error 5100
1. 5100 is a carriage error, check the timing strip for contamination(plastic strip
obstructions.
2. hold RESUME then press & hold POWER release RESUME, then press it twice, the light should go amber then green again.you're now in service
mode (you can release POWER now)
3. This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There
Mar 23, 2011 | Office Equipment & Supplies
Error code 5100. Have tried un plugging and turning off and rebooting. Does not fix the issue. Need urgent help
Error 5100 on canon printers \ This error means that there is something obstructing theprinting process. Check inside your printer through the gears that you can seeunder the lid. There should be something obstructing the gears such as dirt orin my case popcorn. There was even some paper caught underneath the rollersthat I had to jiggle around to even see. Try and this solution
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
Mar 11, 2011 | Canon Office Equipment & Supplies
Printer problem 5100
Mar 07, 2011 | Canon PIXMA MX310 All-In-One Printer
Paper feed not working. green button and orange
I assume you mean that the power and resume lights are blinking. This signals a carriage stall. Open the top cover, if the cartridge cradle moves to the right, it isn't stuck and may be a one-time issue. If it is stuck, unplug the power to the printer. Open the access door and observe the carriage position. Clean any lint or paper pieces out. Remove any obstructions. Move the cradle and continue checking for lint, paper and obstructions until the entire area is cleaned out. If the print carriage started out on the left side, return it to that position to make sure the cartridges are back in the capping station. Look inside the printer along the cartridge cradle path for obstructions and remove any. Remove the rear access door and check for paper pieces, remove any obstructions.
Plug in and turn on the printer and see if the carriage returns to the left and reseats itself in the capping station. Close up the printer.
If this doesn't work, the printer may need service.
I hope this helps.
Mar 28, 2010 | HP DeskJet 5740 InkJet Photo Printer
Lexmark W840 phantom paper jam
Hi! In your case, did you open already your printing?. Because there's still particles left in your printer, usually in the heater roller. consulting to a printer technician is the best way to solve this. GOOD LUCK, thanks
Mar 20, 2009 | Lexmark W840 Printer
Printer carrier stall
I am getting a "Printer Carrier Stall" message and "Check printer for obstruction" message. what can I do to fix it?
Oct 03, 2008 | Dell 966 All-In-One InkJet Printer
Error code 5100
Error code 5100 /this error is an error within the printer. This error means that there is
in my case popcorn. Check VERY thoroughly.
Mar 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
Lexmark X9350 All-In-One InkJet Printer Logo
409 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
