Question about Nikon Superior E Binocular
Fungus inside lens
My superior e 10x42 has fungus in the front lens.I am thinking of servicing the lens.Can the lens be opened or if possible,what about the gas inside.
Thanks
There's nothing but normal air inside your SE. Nikon will service this for you under their No-Fault warranty. See Nikonusa.com for details.
Posted on Feb 03, 2008
Fungus on Rokinon 500mm mirror lens
Do you have a lens collimator and other equipment necessary to ensure proper alignment when reassembling the lens? If not, take it to a good camera shop and have a properly trained and equipped professional do the job.
Nov 22, 2013 | Rokinon 500mm f63 Mirror Lens for Nikon...
Tip
How to avoid fungus on Digital Camera Lens?
The dreaded fungus is something that bothers every photographer. I have suffered from it before, and every coming rain gives me constant worries of possibilities of fungus growing somewhere inside my lenses. I am more vulnerable to fungus than most people because I don't think much about taking out the camera to get some good shots even if it has been raining a bit, and have often got plenty of rain drops on the camera and the lens therefore.
Where does fungus comefrom?
  • Fungus spores are everywhere and germinate under suitable environmental conditions:
  • Relative humidity of at least 70% (more than 3 days)
  • No or little airflow
  • Darkness
  • Nutrients (textile lint, traces of grease, varnish, dust and dirt)
  • Temperatures between 10 and 35°C
How can fungus be avoided?
  1. Silica Gel. This seems to be the easiest and common way to avoid fungus, but I haven't had much success with it either.
  2. . Store the lenses in an airtight container. Again, you may need to put a few Silica Gels in the container. Putting too many of Silica Gel is known to dry out the lubricants in the lens, so you need to use your discretion with quantity of the Silica Gel.
  3. . A popular idea is to install a low wattage tungsten bulb in the closet where you keep the lens. This will keep the place warm and dry, preventing the fungus. This is known to work.
  4. . Store the lens in transparent container. Fungus is known to fear light and love darkness. Also make sure that the lenses are not stored in leather bags, as leather can easily attract fungus.
  5. And finally, of course, the best way to prevent fungus is to get out and shoot more often.
  6. After the work is done, immediately clean the instruments. If possible, you can use a fan or blower to facilitate evaporation of surface moisture.
on Feb 13, 2010 | Cameras
Fungus in lens
como abrir una camara de video
Jan 18, 2013 | Sony SAL-1680Z 16-80mm f/3.5-4.5 Carl...
Smudge showing up in view finder and on photo PowerShot SX210
Is there a visible smudge on the front element of the lens? If so, you can use a LensPen or cleaning cloth from the photo department of your favorite store.
There is the possibility that there is fungus growing inside the lens elements of the camera. Humidity can allow this to happen over time with camera lenses as well.
If you have fungus inside the lens, you may need to check with a repair shop... buying a new camera may be in your future.
Jun 19, 2012 | Canon Slim Camera Case(11160306581) for...
What should i do?...my tamron 17-50 began to have a fungus.
Well, that's a great lens and most definitely worth the cleaning/service. I don't know where in the world you are but fungus growing inside a lens is only heard of in high humidity environments and can happen fairly quickly. Are you sure this is a fungus on the inside and not just a clouded smear on the front element? If the lens is having a problem then the camera won't be to far behind. To answer your question more directly "what should I do" my suggestion is to send the lens to a authorized Tamron service/repair center/depot for cleaning. After which get a few of those little moisture absorbing packets and place them in with your photo gear to help reduce the moisture.
Jan 19, 2011 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
POSSIBLE MOLD INSIDE CAMERA LENS
It is lens fungus and you're correct in your assumption that it's uneconomical to professionally repair on your lenses. But it need to be pretty bad before it affects image quality so don't junk them just yet.
Some types of lens fungus can be killed simply by leaving the lens out in sunlight, but I'd suggest that it's better to leave them exposed to the indirect sunlight on a bright overcast day to prevent any chance of sharply focussed light burning the inside of the lens. Killing the fungus won't remove the dead stuff but it prevents the problem getting worse.
May 29, 2010 | Quantaray 100-300mm F4.5-6.7 Zoom Lens for...
Sigma 70-300 4-5.6 DL has some fungus & blur
Fungus etches the glass. This cannot be fixed by just removing the fungus. The lens has to be resurfaced, calibrated, coated and
well, you get the idea. lots of expensive precision equipment and a jig to recalibrate the focusing after you do all that.
Another 70-300 on Ebay is much less expensive.
Dec 18, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Sigma 500mm lens need to remove funges from inside lens,but funges not showing on photographs is it possible to strip
That is a manufacturer repair. While you may be able to remove the fungus, the fungus may have etched the coating on the lens and still show . The best way to fix that is replace those lens elements that are effected.
Oct 30, 2009 | Cameras
Need to replace large lens cover for Swarovski binocular 10x42
Try Adorama camera in New York. They are good to deal with. Binoculars.com also used to carry parts but I have found since they sold to a conglomerate their customer service is wanting and i switched to Adorama. They also post international.
Mar 13, 2009 | Swarovski Optik (58110) (10x42) Binocular
Nikon Superior E Binocular Logo
518 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
