Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer not picking paper have tried all the trouble shooting
HOW DO I FIX THE PAPER JAMS?
click start , click devices and printers, right click printer image, click trouble shoot and follow directions.
Jul 09, 2015 | Canon NP 6317 COPIER FOR 220 VOLTS ONLY
I am facing the problem with my Canon LBP 3310 the error code E000 0000
If trouble-shooting in the Cannon software does not describe the codes and their fixes, go to support at cannon.com. Enter your model number and go to trouble-shooting there. You should find your fix there.
murf427
Aug 03, 2012 | Canon Office Equipment & Supplies
PAPER NOT RECIVE
Paper not picking up?..shoot print command and observe printer trying to grabbing the paper?..see any marks on paper leading edge? Remove cartridge and see inside paper pick up roller,might be its dusty or warn out, remove the pick up roller releasing the side locks, clean with wet cloth, fix it back then try once, if its success..end the process.. if not replace pick up roller..observe similar kind of machine: 2_4_2012_9_32_43_am.gif2_4_2012_9_33_08_am.jpg
Feb 04, 2012 | HP LaserJet M1005 Printer
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
Paper jam p1005 hp printer
Load paper, give print command verify weather pick up roller trying to pick paper?.. >if yes check pick up roller surface feel smooth?, replace it.. >if no remove right,left and back covers, check solenoid jammed? release it.shoot print command check> if solenoid not acting replace it and verify..
Jan 09, 2012 | HP Office Equipment & Supplies
Hp laserjet 3052 all-in-one printer when i will give print the paper it's not pickup
Was printer trying to picking up the paper,if yes check the pick up roller, if not open back cover check solenoid acting or not, if not acting shoot the obstruction.
Sep 13, 2011 | HP LaserJet 3052 All-In-One Printer
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
The printer won't pick up the paper. there is plenty of paper in the feeder but the printer says the feeder is empty
take all paper out, put half as much back in?
unplug, wait one minute, plug back in, might reset.
lastly, hp has an awesome trouble shooting site, check this out.
good luck
Apr 29, 2010 | HP PSC 1510 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
19 people viewed this question
old marine
old marine
