Question about CDA Kitchen Ranges
Cda extractor stopped working, could the fuse have blown
  • 490 Answers
It is very possible but more than likely the motor went out
Posted on Sep 26, 2009
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
My Acme Juicerator suddenly stopped working. I am worried the motor burnt out. What should I do?
Acme 5001 Supreme Juicerator Juice Extractor Stopped ...
www.fixya.com > ... > Acme 5001 Supreme Juicerator Juice Extractor
Acme 5001 Supreme Juicerator Juice Extractor, stopped working related issues. ...My motor just suddenly stopped working. what happens if a screw peg ...
Acme 6001 Juice Extractor Juicer stopped working - Questions
www.fixya.com > Forum > Juicers > Acme > Acme 6001 Juice Extractor
Acme 6001 Juice Extractor, juicer stopped working related issues. Get free help, solutions ... ...juicer just suddenly stopped working. Mine stopped working after ...
Amazon.com: Customer Reviews: Acme 5001 Juicerator ...
Dec 03, 2015 | Sponge & Chamois Just Swipe Chamois Lens...
Reverse light and brake light not working
More than likely you have blown some fuses.. the reverse light and brake light fuses are located in the under hood fuse/relay block is located near the battery in the engine compartment.Lift the cover for access to the fuse/relay block. You will see fuses to the top right of the fuse/relay block once you remove the cover. These are geneallay spare fuses stored in that location.You can remove fuses with a fuse extractor. The fuse extractor is located in the fuse/relay block itself ...and looks like a pair of cheap plastic tweezers (lol). Ok if you look at the lid of the fuse compartment it shows the location of the fuses... you need to look the location marked STOP LP, CHMSL, VEH STOP, and TRL B/U. Those 4 control the lights in question. I would pretty much guarantee that at least 2 of them are blown. If you replace them and they blow again... that means you have an "short" or overload problem... just contact me again and I will tell you how to fix that. I hope that helps you. Good Luck
Jun 22, 2012 | 2002 GMC Yukon Denali
I have a Hotpoint HE63X extractor hood and the bulb blew yesterday when I pressed the button to switch it on. This has also stopped the extractor from working. All other appliances are operational and...
I've got the bloody thing in bits as I write - I had the same problem as you - and it's the switch itself that has blown! From al the carbon in the swithc unit I would say we were luck the thing did not catch fire!
I'm looking for spare parts now to see if I can get a new switch or a complete unit of switches. The problem will be, it is one new switch, or a new board it all requires soldering.
Just to confimr, there is not a seperate fuse for the lights - perhaps there should be.
Nov 01, 2010 | Microwave Ovens
Cda 9883 - no sound
Check for blown fuses behind the deck and under the hood, sometimes by the battery, you may get lucky but you could have smoked the unit, and would not know anything unless you send it in to get fixed. Replacing the unit could be the answer Alpine CDA-9883 CD Player
Feb 20, 2010 | Alpine CDA-9883 CD Player
Alpine CDA-9856 interrupt message
theres a wire loose, bring your car to an audio tech and he'l sort it
Nov 06, 2009 | Alpine CDA-9883 CD Player
Neff extractor fan not working
Hi rags116,
I'm Harvey the Master Plumber.
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Kitchen Ranges
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
378 people viewed this question
Top CDA Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a CDA Kitchen Range Expert? Answer questions, earn points and help others
