Question about Proscan PS35660 TV
Proscan TV powerup
Proscan CTC189 chasis
will not power up - power button light shows momentarily then goes off,
set will not start
  • Anonymous Apr 14, 2008
    I have the same problem. My husband purchased this tv less than a year ago. Is there anything we can do? I would like to keep it for the family room at a later date.
  • doodle777 May 19, 2008
    turned off one night will not power up again.
  • Proscan Master
  • 19,396 Answers
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 17, 2009
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
Tv wont boot up
This is a prime case of bad capacitors in power supply. You may have only had it a year but how old are the parts that are in it?
Oct 30, 2017 | Televison & Video
How do you set the router ?
From the router user manual on page 13 , it says:
9. Reset The "Reset" button is used in rare cases when the Router may function improperly. Resetting the Router will restore the Router's normal operation while maintaining the programmed settings. You can also restore the factory default settings by using the "Reset" button. Use the restore option in instances where you may have forgotten your custom password.
a. Resetting the Router Push and release the "Reset" button. The lights on the Router will momentarily flash. The Power/Ready light will begin to blink. When the Power/Ready light becomes solid again, the reset is complete.
b. Restoring the Factory Defaults Press and hold the "Reset" button for at least 10 seconds, then release it. The lights on the Router will momentarily flash. The "Power/Ready" light will begin to blink. When the "Power/Ready" light becomes solid again, the restore is complete.
Dec 21, 2010 | Belkin My Essential (ME1004-R) Wireless...
I power on my Precision TV power light comes on but nothing shows
check the power supply
check the horizontal transistor
Jul 06, 2009 | Apex Digital PF2720 27" TV
I cant get the tv to come on it has power
You have a bad power supply (AC adapter). Watch closely at the red light while turning tv on to see if red light momentarily flashes green, then back to red.
Dec 15, 2008 | Proscan 19LA25Q 19 in. LCD Television
Help fix screen t.v.
What red light are you referring to? If you are talking about the red l-e-d power light beneath the screen, that is the power off light. If that red light light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply.
Oct 22, 2008 | Proscan 19LA25Q 19 in. LCD Television
Power button lights up three times but nothing
I have not answered to this post since you have also joined on my thread with is related to the same problem.
Jan 24, 2008 | Proscan PS60690 60" Rear Projection...
Tv won't turn on
Usually this problem is caused by part failure on circuit board. Most often in power supply or deflection circuit. You will need test equip. and soldering/desoldering tools to fix this set. Most repair services charge 275.00-475.00 to do this repair on a PS60690. Crate is removable by removing rear cover, disconnecting spk. plugs and keyboard plug. Loosen two screws and whole thing slides out. This can save you service call fee.
Televison & Video Logo
706 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
