Question about Acer Aspire 3000 Notebook
Once in windows start-up, it automatically reboot again and again and again. what is supposed to be the problem? thanks
  • 6,831 Answers
Hello
I had the same problem a few months ago, but if it is what think, and not a hardware problem, you should be able to fix it with some virus tools.
I suspect it is the virus called ravmon, it did exactly the same with me, but every couple of tries to start the computer it actually stayed on long enough to install a aplication called combofix, it completely deletes ravmon from computer registry and it works 100%. If the computer does not stay on long enough to install combofix, you must take out your hard driver and put it in another computer as a slave device which has a good antivirus(Bitdefender) and combofix installed on it. Once you have done this, scan your HD. Once cleaned up, put it back and it should work if it is a virus.
Otherwise it can be your CPU which is overheating, where some new thermal paste on CPU will do the trick.
Just google combofix, it is very small and free to download.
Really hope this can help you. Also remeber to please rate sollution
Best Regards
Posted on Sep 26, 2009
    President:
  • 1,015 Answers
Try to boot into safe mode. When computer first starts up press F5 and a menu will come up. Pick safe mode with networking. If it boots up then run an online virus scan using housecall at www.trendmicro.com It is a free online scanner and works very well or if you have a virus scanner installed then update the virus definitions and run a complete scan. If a virus is found and removed then make sure to turn off system restore before rebooting computer. This will clear system restore...most viruses will stay in this area and will come back if you do not do this. If there was no virus found then windows start-up files may have been corrupted and you will need to use the windows installation cd to try and repair the installation. You may need to do this even if there is a virus found though because it may have erased critical start-up files for windows. If your computer did not come with installation cd then there will be another partition on the drive that contains the installation software. You may have to press something like F10 or F12 when the computer starts up. Just look for a message that says what key to press.
Posted on Sep 27, 2009
How do I repair a system that boots to the Windows 7 logo and then reboots itself a second time?
I agree (in part) with "map9966's" answer, but instead of trying to blindly load the "last known good configuration", You really should try the Windows Startup Repair option. This option should also be located in the "safe mode" menu, which again access by repeatedly pressing F8 right after turning on the PC. Once you get to the menu stop pressing F8.
Using the arrow keys on your keyboard, highlight the choice which reads (something to the effect of) "startup repair". The PC then *should* "boot" to the start up repair mode. This mode is an automatic utility, and can take anywhere from 15 minutes to an hour, depending on the speed of your PC, the severity of file system damage and the underlying cause of your start-up loop. Let the utility finish, (again, this WILL take awhile.. go have yourself a snack, take a walk, watch some TV..) Once it's done, restart the PC.
In most circumstances (assuming the start-up loop isn't due to a hardware failure), your PC should boot up just fine. If you have any further questions, feel free to contact me!
Sep 14, 2014 | Gigabyte GA-MA78GM-S2H (rev.1.0)...
Laptop in continuous reboot after windows update
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 16, 2008 | Toshiba Satellite A45-S150 Notebook
I cant long in to my account
Follow these step to login in your sysytem- 1. Reboot your windows , once it starts up, keep clicking f8 , this should bring you to safe mode, start windows automatically under safe mode and follow these steps below . 2. Once you're in safe mode, On the bottom of your screen, click "start" menu , Go in to your control panel, find user accounts , click on that. 3. Go into user accounts and find your log in screen name you use example " duckie , and delete password log in, after you have done that now you can restart your system , it should just log you right in automatically without asking for your password. 4. Once you have completed the above steps, go back in to your user account and create yourself a new password and don't forget it this time, it's always safe to run windows with a password and login screen name. hope this helps you..
Thanks Kristin
May 09, 2011 | Computers & Internet
Hi, i got a problem with my laptop HP brand with XP OS..every time i turn on it keeps on rebooting even its starting up..i enter start up windows normally but it keeps on rebooting..it goes only until the...
Hi d_gallos,
you may wanna try to go to safe mode (turn off pc then turn it on again while pressing F8) then find there disable automatic restart when system failure then reboot your computer.it should work fine
hope this helps :D
Apr 05, 2011 | HP Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
WINDOWS ERROR stop: 0x0000007B (0xF78A2524,0XC0000034,0X00000000,0X00000000) WHAT DO I DO? I CANNOT GET PAST THE BLUE SCREEN
The dreaded Blue Screen of Death, as I refer to it as.
If you cannot use a rescue disk to reinstal the damaged files it is a total format and start again I am sorry to say.
Have you got a virus that caused it? If you have a format and starting again is probably the best bet, you can restore your backups when your system is up and running again.
Oct 17, 2010 | Computers & Internet
My Travelmate Laptop will not power on. During an automatic update the server went down and the system crashed I had to turn it off when I tried to startup the power button comes on but the power light...
boot into Windows' Safe Mode; press F8 before the Windows loading screen appears to get this option.
Once signed in, you'll be prompted to a) continue in Safe Mode, or b) Restore a previous install point.
Choose option b) and then follow the instructions. If the same problem (black screen after Windows has started up) persists once you've rebooted, sign in with Safe Mode again and restore to an earlier install point.
change the Automatic Update to notify before installing.
Aug 13, 2009 | Acer Computers & Internet
Remote access to dial-up connected computer
https://secure.logmein.com/home.asp?lang=en
Try this.Set it like after reboot it automatically starts.
Once it comes up you will be able to connect again.
Please rate me if you like my solution.
Mar 12, 2009 | Microsoft Windows XP Professional Upgrade...
Dell Dimension 5100 shuts down then reboots automatically, This is one bugger of a problem. Had continual problem with unit shutting down no rhyme or reason, cant see BSOD message off too fast. Did change...
Try rebooting to Safe Mode. Right-click on My Computer and hit Properties. In the System Properties window, click on Advanced. Then click on Startup/Recovery Settings. Uncheck Automatic Restart. Then post the BSOD Stop Code here.
Nov 18, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Again hep me
just try to reboot the machine,the press F8 when the prompt comes the choose safe moode,the moment you enters windows desktop then reboot the machine. if it won't boot again then just repair winXP OS It will solve the problem for you.
epamost@yahoo.com
Mr CPU......
Apr 05, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire 3000 Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
