Martin Logan Script ESL panel failure. Fuse blown, points to transformer failure. Is there anyone in the Birmingham area that can help with diagnosis/ repair please.
skipper360
  • 58 Answers
SOURCE: blown transformer
Do you know the Input and Output voltage on this transformer? The only advice I got 4u is to find the Identical/similar Input/output/wattage for this transformer or find a shop that can rewind a new wire's on that transformer. Hope this may help you
Posted on Aug 06, 2007
JULIANFIX
  • 975 Answers
SOURCE: blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
Posted on May 09, 2008
  • 293 Answers
SOURCE: Eurovox T/W codes
0=3F 32 37 03 D0 73 84 84
1=F0 83 35 E5 28 40 49 B2
Posted on Dec 04, 2008
  • 5 Answers
SOURCE: starview 1 not working keeps trying to update info but not happen
you can get temp codes off "cable closet" but no fix out for sv1 yet
Posted on Dec 05, 2008
  • 7 Answers
SOURCE: Eurovox codes for Birmingham area - 06/10/09 ???
ntl: 5401
A0 51 3B 27 17 7D D0 28
F0 CF C3 01 F1 2D AB B8
cw: 5c01
BC B6 BB DD 97 AD 11 63
42 B7 84 3E BE 8C 4E 65
hope this helps
Posted on Oct 06, 2009
How can i connect my dynamo 700 w using martin and logan transmitter to my marantz sr5008
You just need one of these though all the sockets would need to be male:
Jul 06, 2014 | Audio Players & Recorders
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
I have the model FMAC101D1PS and now it's not heating. I press the minutes to heat, it run but it doesn't heat anyting.
Most likely causes are an open thermal protector or thermal fuse but could also be blown fuse in HV area of microwave (somewhat uncommon in domestic microwaves).
Less likely causes are failure of other parts in the HV area.
If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron (see repair manual link below).
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses (see repair manual link below).
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • For the various HV parts and how to test them follow this link: Microwave Repair Manual link.
A shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
Oct 21, 2010 | Frigidaire Microwave Ovens
I have an Insignia 42" plasma HD tv. It turned off while watching it. when I tryed to turn it back on I could her click on and I got the green light but it went to red and i could hear it click off. I...
Those transformers on the power supply board have shorted.That why,it killing ur fuse.Which one?Must test and find out,if u have the equipment and the skill.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Sep 08, 2010 | Televison & Video
WHEN THE UNIT IS PLUGED IN AN THE POWER SWITCH IS ON THERE IS NO POWER TO THE UNIT. ANYONE HELP?
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside for blown main AC fuse first, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 245BW Monitor
ntl: 5401
cw: 5c01
hope this helps
Oct 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
Microwave Oven has died
Hi.
Check continuity of this 10A fuse to see if it's blown.
What is most likely to have happened, is that an internal short has happened inside the main transformer. These cannot be rectified, and often means scrapping the complete item due to cost of replacement.
However - if you can find another microwave with a different fault - just remove the good transformer.
Checking the transformer for a short at high voltage is not recommended.
You could try a spare 10A fuse as a start point (probably a leaded type) - but expect it to blow again. DON'T go higher or omit !
Sep 30, 2009 | Microwave Ovens
Panasonic ct 32hx42f blows main fuse
Blowing fuse points to high voltage transformer being short. Check the primary coil of the transformer first.
Dec 14, 2017 | Panasonic CT-32HX42 32" TV
Need a new transformer for an old kenwood stereo intergrated amplifier ax-31 cant find out where to get 1
let me give you a tip ;) power transformer has thermal fuse inside its tape-bounding area. try to locate it and check..transformer might be Ok and fuse has blown.
Aug 13, 2008 | Kenwood Audio Players & Recorders
Blown fuse
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
334 people viewed this question
 Grubhead
Grubhead
