Question about Creative Labs WebCam Live!
Fabricated disk definition what is the solution?
What is a plastic coupler
a piece of plastic that couples/connects two items together, think of it as a link in a chain.-each link couples to the nextA piece of material (plastic in your case) fabricated to affix one or more materials to another. Just about every coupler is fabricated for a specific application. Audio, video, various type hardware, plumbing etc if you need one it is likely you need an exact replacement but not always.... good luck
Mar 29, 2013 | Bosch Exxcel WFO 2465 Front Load Washer
I have a mitsubishi chariot grandis i jus wanna know that can i put any toyotata engine
in theory yes but you will need it engineered i.e.. fabrication of engine mounts, power steering pump, alternator, air compressor brackets fabricated, possible cutting the firewall and getting an engineering certificate to state that its not a death trap......you would also need to buy a ecu to match the engine or get an after market computer then have it tuned. which means also replacing the ignition barrel to take a key for that ecu/engine as they have transponder chips in them
then there is the question of making the gearbox fit to the engine or replacing the gearbox with a toyota one that fits the engine. which will mean fabricated gearbox mounts and either fabricated output shaft or propellor shaft
plus more
Apr 13, 2012 | Mitsubishi Vehicle Parts & Accessories
My BD530 player doesn't play all movies clearly. Some come cover good others re all snowy
When properly connected to a High Definition display or TV, Blu-Ray Disks (BD) should play crystal clearly. Inserting an old "non-Blu-Ray" disk (or the original "DVD") in the Blu-Ray player will display a comparatively "fuzzy" picture. This is the difference between High Definition and Standard Definition. A "BD player" can not "upgrade" the picture quality on DVDs to that of a BD or High Definition picture.
Rent, purchase or choose Blu-Ray Disks (BD) whenever a choice is offered to view the High Definition version of a movie or video. Selecting the DVD version will provide the lower quality or Standard Definition version of the same movie or video.
Check the covers or disk itself to determine if the movie or video is in DVD or BD format. That will tell you what you can expect for picture quality.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 17, 2011 | LG Super Blu BH200 Blu-ray and HD-DVD...
Virtual memory low 81% totle 2.gb usage 146.1 mb free1.9gb how do i correct this john
Your Hard disk space is very low. Try to manage your hard disk space by
  1. Emptying the recycle bin.
  2. Clean disk space (by right clicking the partitions in the My Computer or Computer folder).
  3. Remove unnecessary and worthless data.
  4. Transfer important data to an external Hard Disk.
You problem will definitely resolve. Good Luck!
Mar 11, 2011 | Computers & Internet
Perrin and Rowe, Mayfair Series.- how do you take the perrin and rowe handle apart. The top of the handle has a ceramic disk inserted that says "Hot" or "Cold" and I am not sure whether...
The disk is glued on, but no need to remove. The entire section below the handle spins off, but most likely not by hand (hot did, not cold). I used channel lock pliers and some wood strips that I fabricated to prevent damage to the finish. You then need a thin 17mm wrench to remove the valve. I presume you are having problems turning the cold water handle? Seems common, I am working on it now, looks corroded so I am soaking it in 50/50 vinegar and water.
Nov 12, 2010 | Perrin and Rowe Rohl Bath U-5388 ; U 5388...
I need to replace the rear brakes on my 1995 lebaron are they disk or drum ?
the fronts are definitly disk. If rear looks like front they are disk. If not which is more likely they are drum. Not an easy task. Might let the pros handle the rear drums.
Mar 30, 2010 | 1995 Chrysler LeBaron
I need a new 10 inch blade
A new chain can be fabricated by a local chainsaw shop. A new bar requires a model number to answer, a make couldn't hurt. Tag; you're it.
Lou
Oct 22, 2009 | Remington Electric Pole Saw
Acer computer with 946gzt am motherboard. need i/o shield, how can i purchase one
Contact the Manufacturer or call a local Sheet metal shop and have one fabricated.
Oct 20, 2009 | Computers & Internet
Installation win xp in toshiba sattelite
ok my friend its not that easy but its always possible
fisrt just to know why u r unable to install xp because u have the HARD DISK SATA
and windows xp wont detect it because there are no definitions for SATA HDD.
so what should we do to fix this problem, you will know that by following these steps:
at the begining you need a floppy disk and floppy disk drive (i know thats not available in the new laptops, so u might need to buy one).
ok now we will need to download the SATA definitions from here:
http://www.4shared.com/file/37736514/7da1991f/raid138.html
and save it in the floppy disk (dont forget to unzip the file first).
now lets start the windows installation process (as usual).
u before you get to load the windows file there will be a prompt (in the buttom of the screen) asking you (press F6 if u need to install a third party...........) now press F6 quickly.
you will have a new screen with three options (S= specify, enter= continue or F3= exit).
now lets press S.
you will have a prompt asking you to (insert the labeled disk manufacturer ................).
lets insert the floppy disk now. and press enter
and when its asking you to select definition, select RAID driver.
and when its asking you about windows logo testing press yes.
and after finishing the definition process it will detect the HDD.
now continue installing windows as usual
enjoy XP (i know its a long story but its worth it :)
sure let me know what happened with u and for any other problems plz let me know
cheers
Aug 31, 2008 | Toshiba Satellite A135-S4527 Notebook
Creative Labs WebCam Live! Logo
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
