Question about Lands Phones
I have an old western electric push button phone that won't dial out but can receive calls. Anyone know how to fix this? Thanks!
    President:
  • 860 Answers
Old western electric sets (2500, 2554, 2200 etc.) had a polarity sensitive dialpad which means the telephone line had to be wired a certain way at the jack for the dial to work. Try switching the green wire and the red wire with each other at the wall jack, that should take care of it.
Posted on Sep 26, 2009
What if the phone isnt connected to a wall jack, but a cable box?
Posted on Apr 17, 2013
When I dial out on my 1983 darth vader speakerphone all I get is a busy signal. Anyone have any idea how to fix this?
This phone was made when most phone companies were still using non touchstone systems. When you dial you can hear it simulate an older rotary dial phone. This was how the earliest touch button phones worked. I am not sure the phone company''s systems are still compatible with the rotary systems. Mine does the same thing when dialing out, but receives a call perfectly.
Sep 30, 2013 | Vintage 1983 Darth Vader Speakerphone...
Env3 suddenly quit receiving calls. Can receive
i encountered it many times in my customers phone ,we fix everything ,signal ,software all of the defects that related to call but no luck..and you know what there is only one solution that we discovered ,change SIM CARD and it will be ok..
i hope it will help..
Jun 14, 2010 | LG enV3 VX9200 Cell Phone
Speed dial
1. lift the handset and listen for the dial tone. 2. press the store button 3. dial the number that you wish to store 4. press the store button a second time 5. press one of the numbers on the phone [0-9] and that will become the speed dial number. 6. make a record of the speed dial number and the name of the person it will call.
Then when you want the person on speed dial number 5, just pick up the receiver, get a dial tone and push 5. Thats it!
ps - kindly rate my answer as helpful. thanks
Feb 19, 2010 | Southwestern Bell Freedom Phone FM2552
Do you havew to delete existing phone numbers in Clairity W-1000
Yes I did solve my problem. Just lift the receiver, Push program key, enter full number and push program key again, then push the button above the space you want to store the new number in and hang up the phone. Did not have to delete the old number. Thanks.
May 12, 2009 | Clarity Walker 1000 Hearing Impaired/High...
AVAYA 5610SW IP Phone will not ring, only red light come on
Under the options button. There should be an "Audible alert" option...
Apr 02, 2009 | Avaya 5610 IP Phone
Unable to hang up phone. The line is busy/can't make/receive call
sounds like you need a DSL filter, go to page 41 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Feb 12, 2009 | Panasonic KX-TG1033S Cordless Phone
Dial locked in panasonic KX-TGA351BX cordless phone. How to open
I've got KX-TGA351BX phone. It was in use for 2 years but due to relocation it was out of use for almost a month. One fine day I tried to re-install it and found ''Dial Lock''. Unable to make outgoing calls but can receive incoming calls. Can anyone let me know how to open the lock (I forgot the old password)?
Feb 10, 2009 | Lands Phones
Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Dec 11, 2008 | Toshiba DKT-2020 Corded Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Lands Phones Logo
753 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
