Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Inside screen seems to be getting dirty
Over time, it appears as if the inside of the screen is getting dirty.  Soft focus smudges are appearing.  The outside of the screen is clean.
  • 5 more comments
  • Anonymous Dec 21, 2007
    looks like the inside of the screen is very dusty in the middle of the screen.
  • MrSifter Dec 28, 2007
    I have exact same problem. How can I remove the screen to resolve this? Thank you.
  • Anonymous Jan 07, 2008
    how to clean
  • mikejk Jan 07, 2008
    how do i clean the inside?
  • dloez Feb 07, 2008
    Seems to just progressively be getting worse, the picture is really getting poor please help
  • Anonymous May 11, 2008
    cleaned the lamp. blew dust from inside.
  • mirishfire Jun 18, 2008
    have cleaned and replaced light bulb.Looking inside to the right( with bulb removed) You see a very small clear cover that is loosly attached. This is what has the dust inside it but can't figure out how to get it off to clean it. Used computer air but couldn't get under it. Has 2 scews holding it on but the angle and having to look with a mirror makes the whole thing problematic.
    Problem Solver:
Herman88: Can you please tell me what I need to do to remove the speaker grill? I don't see any screws, and I hate to force it. I'm just not sure what I'm doing wrong, or not doing. Thanks for your help.
Posted on Feb 12, 2008
I had the same problem until I removed the screen and cleaned the front mirror with a static feather duster. First, turn OFF power. Second, remove screws on rear at top and on both sides of the screen. Third, remove speaker grill. Fourth, remove screws on each side of the screen where screen meets the speaker area. Fifth, remove two screws in center area of speaker area under screen. Sixth, lift screen up and away from set housing and use a duster with a two to three extension and GENTLY wipe the noticeable dust layer from the front tilted mirror located behind the screen at bottom of screen. Seventh, do everything in the REVERSE and you're done. If you need to replace the lamp, now's a good time to do so. Also you should clean the dust filter located behind an access door on the rear (right hand side as your are looking at the rear) with a handheld type of vacuum device.
After I completed ALL of the above procedures my WD-62525 was better than I remember. I bought it in 2005 and the picture quality has never looked so good.
The screen is as light as a feather but 62" is awkward. It is recommended you use another person to hold the screen but I work best alone and it was a breeze.
GOOD LUCK.
  • Herman88 Feb 27, 2008
    The speaker grill just pulls off. There are no screws to remove.
My pictures all come out with a smudge depending on the focus is howm noticeable it comes out on the image
This is almost certainly due to dirt on your lens or mirror - possibly your sensor. If you have two interchangable lenses try them both and see if there is a difference. If no difference the mirror or sensor is probably dirty. In either case, I would suggest you have them cleaned professionally unless you are confident about working inside your camera. If there is no smudge with one lens then the other lens must be dirty. Clean both ends carefully with soft, lint free cloth.
Jun 28, 2011 | Sony Alpha DSLR-A100 Digital Camera
Tip
Blurry Photos
Good day,
I have heard a lot of complaints about people taking Blurry Photos.
There are a few possibilities for it and a few easy fixes.
The first possibility I would identify is a dirty lens. To fix this simply take a clean microfiber cloth and gently clean the lens until there are no smudges visible.
The other possibility I would identify is that the pictures are out of focus.
This problem can be caused by a dirty lens or because the object or person was not focused on. To ensure focus on your photos, line up your shot and wait for the camera to focus by pressing the shutter button half way down. When focused press the shutter button in all the way and hold the camera still until the photo appears on the screen. By doing this you will eliminate any motion that might mess up your shot.
Please let me know if these tips work for you!
Regards
on Nov 29, 2010 | Cameras
My screen is constantly blurry except when i am on the menu screens
Good day,
Regards
Apr 05, 2011 | Canon PowerShot A470 Digital Camera
Images are blurry, fuzzy
Good day,
Regards
Mar 11, 2011 | Canon PowerShot SD850 IS / IXUS 950 IS...
The pics are blurry after they are taken
Good day,
Regards
Feb 21, 2011 | Samsung Digimax S500 Digital Camera
Blurry pictures
Good day,
Regards
Feb 20, 2011 | Polaroid a300 Digital Camera
The pictures comes blurry :(
Good day,
Regards
Feb 19, 2011 | Nikon COOLPIX P100 Digital Camera
Blurry pictrues in coolpix s51
Good day,
Regards
Feb 16, 2011 | Nikon Coolpix S51c Digital Camera
Brother HL-2035 laser printer, black dots appearing down right side of paper, 3" apart, after changing toner and cleaning wire.
Dots, Lines and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 08, 2011 | Brother HL-2040 Laser Printer
Smudge looking marks onscreen
If you suddenly noticed it, this is most likely caused by a large piece of dust on the lens. It is hard to clean, you would need to take the whole TV apart in order to get to the lens (mounted on the optical block).
It could also be caused by a failure of the optical block, which had inherent issues. There is a pending class action law suit against Sony for problems with optical block that include smudges, hazes, and tints that appear after a certain number of hours.
Other causes could be a dirty portion of the mirror or a smudge on the inside part of the screen but these are rare because dust and contaminants do not usually accumulate on these parts of the TV.
Jul 14, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
328 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
