Question about Epson Stylus R265 InkJet Photo Printer
I have 2 flashing Red lights on my epson 265 printer
I have 2 flashing lights on my epson 265 printer and it says "part need replaceing2 I have used SSC utility to clear the protection counters but still not working i think i need to reset the counter for prints how do i do this or is it something else?
  • 3 Answers
SOURCE: epson r265 red lights are flashing
I have the r265 fix, it is not an ssc program, and it only works with microsoft windows, not vista or mac, if you want the program, you will need to join my free computer help site, and download it free.
email me at ken57@talktalk.net
Posted on Apr 25, 2008
SOURCE: resetting ink counters on epson c42ux
yes i had this problem also.. . i reset my printer. it did not show the service needed
but after that it will not print anything on paper..the ink goes out of the cartrages. into the machine but it will not print it on any paper..
is there a program i need to reinstall into the printer?? i teied deleting and it said a file is missing it will not let me delete the program nor reinstall it again.. thank you for your time//allan gusse
Posted on May 31, 2008
rockitman187
  • 2559 Answers
SOURCE: How to access waste pads in Epson rx425
They are located directly under the print cartridge when in the resting position.They can be removed with tweezers.
Please rate this fixya
Posted on Jan 28, 2009
gwbm
  • 353 Answers
SOURCE: epson stylus 1400 service utility SSC
The free SSC utility which will reset the waste ink pad protection counter in most Epson inkjet printers can be downloaded from
http://www.ssclg.com/epsone.shtml. Remember though, if you don't change the ink pads, there will be an increasing danger of ink leakage from your printer, particularly if you tip it up for any reason - VERY messy, and it can clog up your printer mechanisms.
Posted on Jan 31, 2009
  • 51 Answers
SOURCE: Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Posted on Sep 26, 2009
2 RED LIGHTS FLASHING CARRAIGE WILL NOT MOVE
On the Epson printer two flashing red lights mean that your printers waste ink tank is full and Epson has locked your printer you need to replace the waste ink pads and then reset your printer using the reset utilities
Mar 08, 2010 | Epson Stylus R265 InkJet Photo Printer
Green light out both red lights flashing alternately
If the lights are flashing alternately then this is the Service Maintenance request by the printer. Usually this is related to the ink pads. You will need to change the ink pads and use a SSC utility.
Feb 08, 2010 | Epson Stylus C88 InkJet Photo Printer
EPSON C60 RED LIGHT FLASHING ON CENTRE BUTTON CANT STOP IT
shellnbarry, As I stated in a previous post the red light flashing means an ink cartrdge is low but not empty. When the red light stays on it means an ink cartridge is empty. You can continue to use the printer until the red light stays on.
Nov 12, 2009 | Epson Stylus C60 InkJet Printer
MY EPSON STYLUS C46 WONT ACCEPT THE BLACK INK WHICH IS NEW THIS IS THE SECOND ONE. THE RED LIGHT FLASHES AND THE GREEN LIGHT STAYS ON
Check status monitor? Black ink not recognized or what? If not recognized, red light just on. But flashes? It's may ink nearly out (low level ink) or printer need service. Check it. using SSC utilty to resolve. Reset protection counter and clear counter overflow.
Jun 27, 2009 | Epson Stylus C46 InkJet Printer
All the red lights flash and 'E' comes up.
you need SSC services utility to solve the problem and reset the eror
May 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Red Flashing lights
hi dear
try to resetting your catridge
or here
http://inkjetprinterhelp.us/epsonSSC.html
oke
i hope your problem clear
good luck
Mar 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus R265 InkJet Photo Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
