Question about Whirlpool Refrigerators
OUR TOP MOUNT WHIRLPOOL FRIG IS DRIPPING WATER FROM THE FREEZER AIR TOWER AREA ONTO THE FRIG SHELVES BELOW. HOW CAN I FIX THIS?
  • Whirlpool Master
  • 1,606 Answers
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Sep 26, 2009
Testimonial: "THANK YOU VERY MUCH. YOUR SOLUTION WAS SPOT ON. I USED ONE OF THOSE COPPER GROUNDING WIRES TO PUT IN THE DRAIN HOLE AND WRAPPED END AROUND BLACK TUBE."
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Water condenses on the ceiling of my frigerator.. and collects in the bottom of the frig, the shelves and drawers.. it does not drain outside the frig and the back of the frigerator doesn't appear to come...
Yes, you may have two problems. The seals around the door are defective or the drain to the pan below the refrigerator is blocked or both. I will need you to read a few things that may help you and I am here to help you get this solved. Now because the water is inside the fresh food compartment I believe the drain is blocked in sid the back and rear of the refrigerator. Look at the first link below and see if this applies to you. Then read the second link and ask me questions if you need. Please rate me and Thank You, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Jul 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Water dripping from top of fridge then freezing under crisper's
HII Your drain line is plugged remove evaporator cover and get a hair dryer and remove all the ice built up on the drain line its a hole just below the evaporator..show here the hole is on the left side.Good
Jan 05, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
