Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I have desktop and recycler and system volume folder problem
I have desktop.ini and recycler folder and System Volume Information folder problem so i the desktop.ini problems
    Sergeant:
  • 155 Answers
Try to clean boot ur pc it'll help u.
for clean boot go to this link:
http://support.microsoft.com/kb/310353
Posted on Sep 26, 2009
I've been using my windows formatted external hard drive in my macbook pro in the past week and everything was working well. Until today, I was deleting unnecessary files and folders. I encountered an...
Were those files and folders something like System Volume Information, System Restore, Recycle Bin, and Desktop.ini? If yes then these are the folders that store the data about what is in the NTFS partition - deleting them makes the partition unreadable.
To recover your files from it you must install this program in a Windows pc
http://www.softpedia.com/get/System/Back-Up-and-Recovery/EASEUS-Data-Recovery-Wizard-Free-Edition.shtml
and run it. A better but paid program
http://www.easeus.com/datarecoverywizard/recover-formatted-partition.htm
Jun 10, 2011 | Samsung G2 Portable External HX-MU064DC/...
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
My system volume information and recycler are problem . so i am inserted a pendrive that is not opened. it denoted only access denied. what i do
System volume information folder on NTFS is locked. You cant access it. And you needn't. Plus, you can access the recycle bin directly.
Be clear on question the next time.
Aug 11, 2010 | Microsoft Windows XP Professional
How to remove autorun.inf, system volume information, recycler etc virus from the harddisk.
1st: Go to Tools>Folder Options>View>unckeck this items below:
1>display the contets of system folders
2>hide extensions for known file types
3>hide protected operating system files(Recomended)
2nd:check all other options in VIEW
3rd:APPLY>OK.
4th:Download unlocker 1.87 ,install it after that enter any drive (C:,D:,........) and delete the recycler folder >then a error message will appar and shows that " can not delete RECYCLER:access is denied." it's in use.>click "OK">after that the "unlocker 1.87" will appears automatically and will give options "noaction","delete","rename","move" at down-left corner and there you can select " delete" optinon by scrolling down and after that you can success fully delete the virus,RECYCLER,from that drive.:D
continue this proccess for all drives where you can see RYCLER folder
NOTE ADDED: This site is listed by McAfee Site Advisor as a potential source of adware and malware.
another answer::::::::::::::::::::::::
Use a batch file (Example.bat) to change it from to a non hidden and a non read only file. It will convert it to a deletable folder and delete it. Do not delete the Autorun file because I found that the virus changed one of my documents to the autorun.
@Echo off
ATTRIB -S -A -H -R
Pause
Then if no errors come up after running the batch right click on RECYCLER folder and click delete.
Make sure the Batch is in the drive not the subdirectry.
(Example) - DriveLeter>Example.bat
Hope this helps : )
Please note that the following advice if taken will absolve me from any responsibility. I am only reporting what I did to get rid of the virus installed on my hard drive.
1. You should be able to see your root drive root drive which is c: or d: etc.
2. Ensure that you are able to see hidden files by going to Tool>Folder Option>view and checking off hidden files.
3. System Volume Information and Recycler should be visible in your root drive (c: d: or whatever drive you use)
4. Right Click on Recycler folder and go to Properties.
5. Go to the tab labeled Security, If your user name is not there then add your username that you use for XP . Give yourself all security rights as well as the SYSTEM user. Then press okay. If you cannot see the security tab and you are using XP professional then go to Tool>Folder Option>View uncheck box "Use simple File sharing" then select Apply.
6. Right Click on System volume information folder and go to Properties. Repeat step 5.
7. Go to the garbage icon on the desktop and right click. Choose properties then check the box " Do not move files to the recycle bin. Remove files immediately when deleted." Press Apply.
8. Go back to the root drive and delete Recycler folder.
9. Go to the System Information folder and delete the last folder. These folders are where Xp has taken a snapshot of your system in order to restore it. The virus is hiding here in the event that you restore it is also restored.
10. You should now open the registry editor and remove the virus from here so that when you restart the virus is not recreated.
11. Open the registry editor. Start >Run> then type regedit in the box and select OK The registry will now open.
12. Hit Ctrl+F Type Recycler in the search box . Delete the entry when found. press F3 to find the next occurrance of Recycler and delete.
13. Close regedit.
14. Go to all installed harddrives and so steps 2- steps 6, steps 8 and steps 9.
15. Run your virus software. You should be able to update any virus software that was previously unupdatable.
16. Reboot your computer
17. Verify that that the reycler folder is deleted from you root drive.
18. Then you can uncheck the box in the garbage that you checked in step 7. To keep all you deleted files in case you need to restore a file that was accidentally deleted.
My findings: This virus is recreated using the methods of the garbage bin. Everytime you delete a file it recreates itself because it looks in the garbage and restores or copies the virus information inside. If the virus is not able to be stored inside and is immediately removed when you check the box in step 7. Then it cannot recreate itself and all of its power is lost. So erasing it from the registry and drive ensures that it cannot return.
I frequently get this headache and finally heartache sooo annoying it had brought too much trouble for me. After installing various kinds of software, running them and so on, I found some of them useful and some of them not at all effective.
Even if we make changes in folder options to view all the files and change various settings, searching through regedit etc or following by some software, in most conditions a typical average user lands in confusion and finally some disaster happens to his system.
I found this simple system to effectively remove Recycler virus - Blam to Recycler virus.
1. Go to Desktop, right click on Recycle bin and select properties.
2. Check (select or put a tick mark) on the square box (Do not move files to the recycle bin. Remove files immediately when deleted)
3. Get File zilla FTP which is free and install. (you dont need to change any file settings)
4. without entering any sort of web address anywhere click the directories in the Local site box.
5. Then each directory will display all the folders below this box with file name, file size, file type and last modified.
6. Now check if RECYCLER folder is there. Then simply delete it.
7. Your job is done.
8. Repeat in all the folders by searching if it is sub folders too.
9. Repeat for each directory ( C D E F ...)
After your job is done again go to desktop, right click on recycle bin and then deselect on the square box.
Apr 21, 2010 | HP Computers & Internet
$Recycle.Bin and System Volume Information
please click start->all programs->accessories->windows explorer right click it and select RUN AS ADMINISTRATOR
when a new window appears go to the drive and delete what ever you want
you can also use winkey+r and type explorer and press enter and do the procedure as stated above
Hope this helps
Please rate
Thnx
Waqat
Jul 17, 2009 | Microsoft Windows XP Professional With...
RECYCLER FOLDER Virus or Malware in all drives.
If you remember when you got this virus or whatever it is. Try to restore to an earlier date, by going to Start, Programs, Accessories, System Tools, and System Restore. Choose roll back to eariler date and pick a date.
Mar 15, 2009 | Altec Lansing ADA995 Speaker
I can not remove viruses from my hard drive ...
"System Volume Information" is not a virus; it is a folder where your system restore points go.
"Thumbs.db" is not a virus but a program windows uses to create thumbnail images.
"Recycler" is not a virus but the location of the recycle bin.
The reason these items are "ghosted" are because they are hidden files; removing these files/folders can have adverse affects on your computer and if you did succeed in removing them, windows will just recreate them because they are not virus related.
If your current antivirus is up to date and running okay, then you don't need to switch. It sounds like you do not have any virii.
Oh and one more thing, please take a moment to give this solution a rating of fixya. Thanks!
Feb 02, 2009 | Microsoft Windows XP Professional for PC
How to remove recycler and system vol info folders
what antivirus do you have? most of them can easy remove it... i had the sam problem... but here is a list of antivirus programs, i know that they can remove it:
Norton Antivirus, and internet security
Kaspersky Antivirus, and internet security
ESET Smart security /can only stop these virus from coping itsepf on the PC, but can not delete it if you install it later.../
as i know Recycler is not that dangerous... but it is a pain in the ***... you can also try to delete ot from the registry /in safe mode/
Jan 16, 2009 | Microsoft Windows XP Professional With...
Folder named as recycler and system volume information are appearing how to delete those
You should not delete this folders in any circumstances, as those are system folders used by your operating system.
They are also hidden folders, so if you want to get rid of them, you will have to make Windows to not display hidden folders.
Go to Tools -> Folder Options in Windows Explorer, open View page and check Do not show hidden files and folders.
Hello, I am experienceing difficulties with my PC. I can't access to any folders and cant open the start menu.
You might have a Virus. In the case of a Virus infection I would most likely disconnect the Hard drive from the machine, scan it on another machine ( using AVG7 + AVGAS = AVG Antivirus and AVG Anti Spyware Scan) remembering to turn off system restore while scanning on the drive.
If you have successfully found and removed the virus infection, remember to delete your system volume information and recycler folder on the drive. virus files tend to infect these folders.
When you plug in your HDD into your machine again, you might want to do a Windows repair; to fix the issues that the virus has caused OR use a registry repair tool to repair registry items. Another option would be to create a new user name. The settings in that new accound should be working fine and you should be able to access the start menu and your folders again.
Apr 17, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
