Question about Kitchen Appliances - Others
I have a 110v motor with 2reds 2 whites 2 blues
I have a 110v motor with 2reds 2 whites 2 blues and 2 blacks cant wire it
  • Chemist1961 May 11, 2010
    Multiple leads indicate a multi speed motor, please post back with more info, as to model speeds, etc.
    President:
  • 1,714 Answers
Study the name plate, there will be a diagram for different speed and voltage configurations.
Posted on Sep 26, 2009
Trying to wire a single phase 1HP motor to a standard hot, neutral, ground plug. J10 Black ----] 2 White----] low volt line T4 Yellow---] P2 Brown----] T3 Orange---] T5 Red--------] P1 P
didnt specify to much --generic answer -- sounds like hooking up a heating or cooling unit black and white should be your line voltage use a meter to test your black and white line for 110v if motor is 110v the low voltage lines are control or switch lines that dont go to motor they usually go to a thermostat or transformer
May 04, 2017 | Cars & Trucks
Replacing home a/c blower motor the unit has black and white wires my new motoe has blue lack red and yellow wres How do i wi it?
DO YOU HAVE A WIRING DIAGRAM OF THE NEW MOTOR? TYPICALLY NEW MOTOR WILL HAVE OPTION FOR MULTIPLE SPEED MOTORS.
WIRES ON UNIT NEW MOTOR
WHITE.............................NEUTRAL.........WHITE
BLACK ...........................HOT...................RED=LOW
OPTION 2 YELLOW=MED/LOW
OPTION 3 BLUE=MED/HI
OPTION 4 BLACK=HI
Dec 09, 2014 | Heating & Cooling
I have a 220V circuit (1 black wire, 1 white wire, and one green ground wire. The new stark industries pool pump has three terminals plus a ground, There is one terminal for a black wire (terminal A) and...
First, be absolutely sure that your motor is wired for 220v. If it is 110v and you apply 220v the motor will die instantly (after a loud bang). Also verify that your supply is in fact 220v.
Without exception 220v power should be supplied by two wires of the same color, as they are both "hot". Black and white wires are common in 110v wiring, the black being hot and the white neutral.
Every pool pump I have worked on has had two terminals where the wires attach to the motor, L1 and L2, wire orientation does not matter.
Evidently yours only has one. Apparently there is no wiring diagram on the side of the motor either, which is also atypical. Best bet is to call the factory for assistance with this.
Dec 22, 2013 | Pool & Spa
Triing to install intermatic t103 please help. Source is 3 wire 110v want to run 3 blower 110v 9.5 amps each off the t103 timer. Don't have 220v in house just 110v. I need a very simple wiring diagram I...
T103 has 120Volt clock motor, so we can wire this timer.
T103 timer is rated for 30 amps and 2horsepower and your blowers use 28 amps.
So we're getting close to max on the timer. Hopefully blowers won't all be started at one time since motors draw maximum amperage when they start.
However, you need 30 amp breaker and orange 10 gauge wire for that much amperage >> unless only one blower is turned ON at any given time.
Always match wire size, amperage of breaker and amperage of Load or it will trip the breaker.
If you put 30 amp breaker on size 10 wire it is good. But 30 amp breaker on smaller size 14 or 12 gauge wire is fire hazard.
http://waterheatertimer.org/Color-codewire.html
Add a comment at any time, and I will respond
Look at the basics:
You have 2 cables.
One cable comes from breaker box.
Other cable goes to three 120V plugs (120V is same as 110V).
Each cable has black-wire, white-wire and bare-copper-ground-wire.
How to wire the timer.
Timer has 5 terminals: A 1 2 3 4
A) Cable from breaker box:
White wire from breaker connects to terminal A
Black-wire from breaker connects to terminal 1
B) Cable going to 3 plugs
Black wire to plugs connects to terminal 2
White wire to plugs connects to terminal A
Ground wires connect to green ground screw.
Terminals 3 and 4 are not used in this case.
Here is a wiring diagram that shows 120Volt from breaker box and 120Volt going to Load
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Nov 27, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Wiring of the 2-5-10-15 timer to a jucuzee bath tub it has three wires black blue green. Thanks. Terry.
First thing to consider is size of Load.
Leviton countdown-timer Load rating is 1800 Watt, 120Volt.
Look inside Jacuzzi at rating plate on motor.
Rating plate on motor should give Volts, Watts and Amps.
Formula Volts x Amps = Watts.
Sometimes motor shows VA which is Watts
Is Jacuzzi on 240Volt breaker or 120V breaker?
Leviton countdown timer is not for 240V load.
A) If 120Volt electric Load checks out, here's how to wire timer if 1 cable enter box.
Timer-black-wire connects to jacuzzi-black
Timer-white-wire connects to ground.
Timer-green connects to ground.
Timer-red connects to jacuzzi-blue.
B) Here's how to wire timer if 2 cables enter box.
120Volt cable coming from breaker box has black, white and bare copper wire.
Timer-black-wire connects to black-wire-from-breaker
Timer-white-wire connects to white-wire-from-breaker-box.
Timer-green and jacuzzi-ground connect to ground
Timer-red-wire connects to jacuzzi-black-wire.
Jacuzzi-blue-wire connects to white.
I am puzzled why this wire is blue if circuit is 120Volt.
Nov 26, 2010 | Leviton Timer Switch 2-5-10-15 Minutes, 4...
Model T104P wiring instructions for 110volt motor
T104 timer is for 240 Volt circuits. It has internal 240V clock motor. Clock terminals and timer terminals are connected, so there is no way this timer can control 110V circuit.
T101 timer is for 110V circuit.
T101 has 110V clock motor
Both white neutral wires = terminal A.
Black hot wire from breaker box = terminal 1
Black wire to load = terminal 2.
Grounds = green screw
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
T103 timer is for 110V circuit
T103 has 110V clock motor
Black hot wire from breaker box = terminal 3
Black hot wire to load = terminal 4
T1905 timer is for 110V circuit.
T1905 has 110V clock motor
Both white neutrals = Clock terminal
Black hot from breaker = COM
Black to load = NO [load comes on when timer turns on]
Sep 21, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How do I switch the voltage on a delta Dj20 8" from 240v to 110v
I had the same problem as you.
You will find these two links useful:
http://www.electricmotorwarehouse.com/motor_connection_diagrams.htm
http://books.google.com/books?id=DDsh3lPokL4C&lpg=PA100&ots=N26cU5VS66&dq=wiring%20standard%20single%20phase%20dual%20voltage%20motor&pg=PA101#v=onepage&q&f=false
The first link shows you the NEMA standards for wiring a single phase dual-voltage motor. In the 'Dual Voltage: (Main Winding Only' table, the numbers are the terminal numbers on the motor. You will see to the left the standard color coding for each terminal number.
The second link shows you how a two mains winding/one start winding motor is wired, using the same terminal number convention. Note that Figure 8-32 is mislabeled; The T2 at the bottom should be labeled T4.
The reason it is a bit confusing for 220V as factory wired by Delta is they switch the T8 (Red) wire with the T5 (Black) wire against what the name plate recommends.
These leads are for the starter winding, which is used to get the shaft spinning in the direction that you want. The nameplate on the motor is for clockwise (CW) rotation, but the motor as mounted in the DJ-20 runs in counter-clockwise rotation (CCW).
So, the starter winding leads are flipped to get the shaft going the other direction (see http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor for a brief discussion; important takeaway 'phase lag' generates a magnetic difference that gets the shaft spinning).
For the question you asked: For 110V wiring,you need line 1 (probably black from the switch, its not too important) should blue, orange, black and for line 2 (white from the switch) should be red, white, yellow.
If for some reason the motor runs clockwise, just switch the red and black wires.
To add, on my motor name plate, it spells out you need to switch these two wires for CCW direction.
Don't forget to review your switch too. Generally, the black and white wires are both wired through the switch (dual pole), but for 110V, you just want the black wire running through the switch, and the white wires twisted together. In theory, this should be shown on the switch, but I haven't opened mine up yet.
Sep 18, 2009 | Delta X5 Dj20 8" Precision Jointer
Wiring My Pool Pump
that pump is probably prewired for 220volts. you will have to check the diagram for how to configure it to 110v. most motor can be converted to 110v. If you are not comfortable with reconfiguring, contact a service tech.
Sep 13, 2009 | Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Kitchen Appliances - Others Logo
88 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
