Question about Black & Decker Garden
How do i change the blower element on the g250 to the vacuum? thanks
  • 437 Answers
I would advise not using it to vacuum with. The impeller/fan is made of plastic and when an acorn or small piece of limb hits the impeller, it will break off the impeller blades. You would then have to replace the impeller because the unit would be off balance and vibrate like crazy.
Posted on Sep 26, 2009
"yearly Maintenencae" what is
thay clean and change the o-ring the needly seat and new diaphram its some thing that you do every year to certifi for ins. purposes
Apr 23, 2011 | Scubapro MK25/G250 Hp Regulator
I have a charmglo electric fireplace blower works but there is no heat is it the thermal cutoff and if it is what do I replace it with and also can it be put in backwards
More than likely it's the Thermal overload circuit or the heating element has given up the ghost.
As I just told one other questioner. These types of electric fireplace heaters were not designed to run for long periods of time. Their heat output is not much more than a blow drier. However, this is not just a problem with CharmGlo, it's with all the manufacturers.
Here's the problem ... The heaters work by taking in cool air, heating it and sending it back out via the blower. Over time, the heating element and/or blower become clogged with dust, lint and/or pet hair. This makes the heating element work harder and it over heats. Either burning out the heating element or the thermal overload switch or both.
You can try cleaning the heating element with a vacuum that has a hose and a brush attachment. While you're at it clean the blower fins and motor. Consult your Owners Manual to see how to access these parts, as they are under firebox, behind the metal grill on the bottom of the firebox, so to speak.
Feb 05, 2011 | Heating & Cooling
Older leafhog don't know how to change over to blower instead of vacuum model Bv2500
Remove the vacuum tube completely from the bottom of the machine and make sure the impeller cover closes completely. Remove the collection bag off of the blower outlet. Now attatch the blower tube to that outlet on the blower. Done.
Dec 07, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
I can not get the Leaf Hog to swtich from vacumn to blower. Any suggestions?
it does not "switch"
The air intake becomes the vacuum with an attachment. The "blower tube" is then the vacuum exhaust.
the motor does not change directions.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2010 | Black & Decker Leaf Hog Blower Bv4000
B & D leaf hog (blower/vac)
Check an see if a branch or something got caught in the blower an won't let it turn, if it hums that could be the problem
Nov 11, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Garden Logo
305 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
