Question about Cameras
What is the max size of SD card that can be used in a ViviCam 3785?
  • 3,289 Answers
Any SD card will work in this camera. The largest capacity card is 2 GB. There are cards that look identical to SD cards that have much larger capacities, but these are SDHC (Secure Digital High Capacity) type cards - not SD cards; an will not work in your camera.
You can download your camera manual here:
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Posted on Sep 26, 2009
How do I clear the internal memory?
This should do it - this comes from the manual Formatting will do what you want.
Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
Added new memory card. Camera says that the memory card is full..How do I correct this?
Assuming it is not actually full, this might mean the card is incompatible with the camera (too high a capacity) or it might mean it needs formatting. Usually a camera will say if it needs formatting, so I would check the camera specs to see whether you have a memory size it can handle. SDHC cards are not backwards compatible with SD cards.
Oct 22, 2010 | Vivitar ViviCam 3785 Digital Camera
I have just brought a vivicam x327 camera and i have just seen it says i need a memory card to use it. Where can i buy a memory card and is there a special type?
You need to use an SD or an SDHC card. They should be available at just about any department, electronics, or office-supply store.
Jul 10, 2010 | Vivitar ViviCam 3785 Digital Camera
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
2. Press the MODE button twice to enter Playback mode. Then press
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
has been formatted.
If you need a manual for your camera you can download a free PDF at
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
Can i use a 2 gig sd card in the vivicam 3785
Manual says that camera only supports up to 512MB. Just tried it with a 2GB card now--gives a "Card Full" error.
Oct 12, 2009 | Vivitar ViviCam 3785 Digital Camera
When i try to view my pictures a memory error comes up.
most likely the memory you are using is either corrupted or not damaged, try using a diferent one similar to the SD card you are using...
cheers
Dec 15, 2008 | Vivitar ViviCam 3785 Digital Camera
I can't find the memory card slot on th 3785 camera. where is it.
I checked out the user manual and it looks like the SD memory card slot is located right next to the battery. Just open the battery compartment and look near the hinge and you will see a place to put an SD memory card. Here is a link to a pdf version of the manual which is nice to have even if you have the printed version:
Click HERE.
Take Care,
-WN
Aug 19, 2008 | Vivitar ViviCam 3785 Digital Camera
Driver
Try the manufactureres web site.
However if you computer is a Windoes machine[ME/2000/XP/Vista
No disc or sofrware is required.
Windows can do it all
Nov 03, 2007 | Vivitar ViviCam 3785 Digital Camera
Cameras Logo
144 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
