Question about Cameras
I buy an multrie game camera on line an the flash
I brouth an multrie game camera on line an the flash card not working what should i do
Will an8gb compact flash card work in my finepix m603 camera
Your camera can't Please don't try to put any SD card in your camera. It will destroy the camera. You camera only accepts xD cards. It is a complete different card size and works different.
There are xD micro drives, but I would not buy them. it is a very small HD and are not made for years. So if you find one, it is likely it is defect.
But if you can find a 1 Gb xD card, you can put lots and lots of pictures on it.
The manual is still online
http://www.fujifilm.ca/shared/bin/Manual_M603_EN.pdf
Feb 12, 2015 | Fuji FinePix M603 Digital Camera
Moultrie i40 digital game camera will not flash
run diagnostic test and cover sensors with thumb...may have to shade IR flash array to see it glow red...menu may start countdown...if flash doesn't glow you will get a 020000 error(flash/flash charging error).To fix you need to remove batteries,sd card,rubber plug from remote slot, 5 screws from face;lift out face and turn over. Remove 4 screws, keeping separate from other screws, from camera card and carefully unplug (3 plugin connectors) and carefully lift camera card out..no soldering required up to now..2 conductors,a red and a black, connect to the flash array at one corner...these go to the sensors on the face,slightly under main board...either the sensors are bad or the array is bad...getting replacements is the problem unless you can get them...I buy "as is" cams off eBay.
Dec 14, 2011 | Moultrie I40xt I40xt Trail Camera 50 Mp
My camera flashes "note: if sd card is
After Note: , it should say internal memory must be erased in order to use the SD card. Yourn LCD is probably about to puke so you don\'t see the second line.
Have fun with the junk LCD replacement parts.
Sep 17, 2011 | Moultrie 6.0 Game Spy Infrared Camera...
Dear sir , photoprints from my camera shows parellal lines when the picture is zoomed the lines becomes bold from...
This is can be due to sensor damage or memory card damage.
  • Card damage (maybe repairable).
This is common with Flash memory that has been used extensively for a long time and this problem is likely not caused by any fault in the camera.
To check whether the damage is on the card or on the camera, copy a good picture from your computer and check it a few days later with a COMPUTER. If the lines appear on them too, you can say that the card is damaged.
If you want to try to use the card again, You can try formatting it (method differs from cam to cam, check instructions manual for specific instructions)
If this doesn't work, You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk.
  • Sensor damage (unlikely to be repairable):
If you pointed the cam directly at something very bright like the sun (for taking pictures of an eclipse for instance), some parts of the sensor will get burnt. In this case you will get oddly colored dots all over the pics in the same places.
Parallel lines are consistent with other kinds of sensor damage like because of water.
I'm afraid that you might not be able to find someone to repair this cam; it's not a professional DSLR camera. which means repairs to it can cost more than buying a new camera will!
May 02, 2011 | Canon PowerShot A470 Digital Camera
Camera still reads full and will not work when new memery card installed
I had the same problem. Your memory card likely has too much memory. I put in a 4G card and it would not take a photo. Every time the camera went off it said "Error - Card Full".
You have 2 options.
1.) You can remove the memory card and use the internal memory to take photos (it will only hold 20 pics) and transfer them onto the memory card by shutting the camera off, inserting the card, turning the camera on, wait for the menu to clear and then shutting the camera off again and removing the card. This does work, but you are limited in the number and quality of photos that you will get.
2.) Get a smaller capacity memory card. I went out and bought a 2G card. Funny thing is that the camera wouldn't even recognize it at first. When I turned the camera on a message saying "Please wait" kept flashing on the screen. I waited 10 minutes and just shut it off and pulled the card again. I took the card home and formatted it on my PC. When I put it in the camera the next time it worked fine. So to save you some trouble, buy a smaller card and FORMAT it on your computer before trying it in the camera. It will save you a headache. After all of that BS I finally got the stupid thing to work. It takes beautiful pics but I will not be buying another Cuddeback. My next trail cam will be a different brand for sure. Not worth the hassle IMO.
Sep 02, 2010 | Buck Cuddeback Expert Game Camera
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
Out of Memory?
Check the camera. Many older cameras cannot use the newer larger than 2GB memory cards. If your camera cannot us the UDMA type cards you will have to buy a smaller card.
Nov 18, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
I FORGOT MY PASSWORD TO MY MULTRIE DGS-I60 AND DONT WANT TO SEND IT IN IS THERE ANY WAY TO UNLOCK IT MANUALY
..according to Moultrie, you MUST send it in with a VALIED receipt and $25 and they will reprogram it...NO EXCEPTIONS.
I am also looking for a way around this; bought two used cheap with this prob. And of course my receipt is not from an authorized dealer.
Oct 08, 2009 | Moultrie MFH-DGS-100 Digital Camera
Pics on the card, but computer won't recognize the card
do you have the drivers installed on your pc to run the card?
Sep 21, 2009 | PNY 2GB microSD Memory Card
Geforce fx 5200
it could be that your video card is overheating up try putting some cooler system or fans on it. I had this same problem with my card the only solution for me is to buy a new card.
Jul 29, 2007 | ASUS GeForce FX 5200, (128 MB) Graphic...
Cameras Logo
11 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
