Question about Samsung SH-S182 DVD±RW Dual Layer Burner
My cd/dvd drive is working properlly with cd but not showing anything in case of dvd
  • 832 Answers
Buy the CD/DVD Cleaner Disc from the dealer selling CD/DVD music,and video. Hope this will correct the defect . Give us your feedback via e mail and vote if this work.
Posted on Sep 26, 2009
  • 6,831 Answers
Hello
I had the same problem. All i did was to buy lazer head cleaner disc, which you put into your rom and run the cleaning test. Mine worked fine after i did this. It is very cheap and you can use it repeatedly. You can buy it at any music store. Please rate this.
Best regards
CD Drive is not reading disks
It will cost about $30 to buy a brand-new CD/DVD reader/writer to replace your "dead" (broken laser) optical device.
Feb 16, 2010 | Compaq Laptop / Notebook Video-336970-001...
Tip
Dell vostros 220 cd/dvd drive not working
my cd/dvd drive quit working device manager showed the triangle and ! mark, properties showed code 10. shut power off, took side case off, unpluged both cd/dvd's, from the board, restarted machine let it reboot, shut power off again,plugged both cd/dvd's back in, restarted machine, both were reinstalled and now working. hopes this is some help to somebody else. thanks jim.
on Jun 22, 2011 | Dell Vostro 220 Desktop Computer
How can i tell if my cd dvd drive is stuffed or not programed properlly. I have down loaded update still not wokin Please help
Go to Control Panel....Devise Manager .....find you CD/DVD player on the list...click on it ......there should be a option to replace the DRIVER for this device. If there is a yellow exclaimation point next to your CD/DVD player it is probably bad IF you have installed and reinstalled the programing several times and it still does work. On a rare ocassion Windows Update can fowl a player. Very LAST thing to try is roll back the latest Update. You might also try doing a System Restore to a point before the CD/DVD player went out.
Oct 12, 2009 | Microsoft Windows XP Professional With...
DVD Writer not recognizing DVD
the drive is not recognizing any dvd. this happens when you insert dvd into cd drive. if this happens with dvd drive its factory malfunction probably so if you can-replace it
Oct 02, 2009 | LG GSA-H55N DVD-RAM Burner
Power dvd will not run
chech an see if there is a hole that you can put a pin into open it, if that does not work go to the run box under start and type in device manager and then click on the cd rom troubleshoot if is working properlly. if is not then you need a new drive
Jul 25, 2009 | Computers & Internet
I have an erroe message I can't get rid of.
hey buddy this is the disc problem ...but some time dvd or cd drive can not read the disc properlly..and give u this erroe. that's mean ur cd or dvd lens get very very dirty..first try to clean it with the help of cd dvd lens cleaner... if the same erroe is come again then u need to change ur lens..or ur drive..
Jun 06, 2009 | Compaq Armada M700 Notebook
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
May 28, 2009 | E-Machines eMachines Desktop PC
Cd/dvd driver
Hi
cd/dvd drive doesn't require drivers at all, the drivers come with windows and if you are missing or corrupt drivers on the cd / dvd drive then
try this:
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
if that doesn't solve the problem then use the windows cd to install windows to the computer again and start over or use the restore cds to restore the computer.
Apr 11, 2009 | Acer Aspire 4720 Notebook
Dell D600 not reading any type of disk
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Jan 14, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Not working
Is the drive connected propperly ?
look at the jumper settings if its IDE
if it is connected propperly and still doesnt show up
( verify its showing up in My COMPUTER)
try it on anoter PC to see if it works.
Just cause its new doesnt mean it works
If it works and you did connect it propperly the let me know
IS IT READING ANYTHING ?
Is IT SHOWING UP IN YOUR DEVICE MANGER?
Click START, (right Click) my computer, select properties then device manager, it shoud show up in DVD/CD-ROM drives
if it doesnt then right click on anything and scan for hardware changes. If it doesnt show up then it isnt connected propperly.
Oct 13, 2007 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Samsung SH-S182 DVD±RW Dual Layer Burner Logo
152 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
