Question about Amana 24 in. ADB2200AW Built-In Dishwasher
Black residue My Amana dishwasher leaves a black residue on all dishes. The residue does not adhere to the dishes as much as detergent or food would, and is fairly easy to rinse off in the sink. It originally looks like coffee grounds at the bottom of a cup, but upon closer inspection it appears to be small particles of black rubber or plastic. When I put clean glasses in and just run them through the rinse cycle, the problem is the same. I have repeated this several times with clean glasses and the amount of black residue is the same each time. This dishwasher is 2 years old and I believe the problem has always existed and is getting worse. My guess is that something is slowly breaking apart, but I don't know what it might be...
  • BadGasket Feb 05, 2008
    I'm having the same problem. I have a Kenmore, model # 665.16032403. It's a year and a half old. I suspect the residue is from the door gasket. I'm considering legal action becuase I don't see why I should have to foot the bill for a new gasket and labor when it's obviously a defect.
    Problem Solver:
  • 15 Answers
The black residue is possibly rust from iron pipes. I have an old house with iron pipes and when the washer opened the valve that lets water in from the supply hose it did so suddenly and created a "water hammer" that shook the pipe. The hose supplied with the washer became clogged with this black rust material and needed to be replaced. I replaced it with a different type that did not have a spill proof valve and added an "air cushion". An air cushion is a short 6" vertical pipe teed before the valve. It fills with air bubbles and cushions the shock of that valve turning on thus stopping the pipes from shaking and the loosing of interior pipe corrosion. If the black residue is hard and gritty it is rust not rubber. Wipe the inside of the washer clean of it. Disconnect the supply line and fill a five gallon bucket with it. If rust is coming from the inlet you will see it in the bucket. If you don't have a shut off valve at the washer you'll want to put one on now as turning off the main releases quite a lot of material from the pipes as they drain.
Posted on Mar 08, 2010
  • 22 Answers
Maybe a ruber washer is breaking apart, But my advise is take the inside apart clean and inspect it and then test it.
Posted on May 12, 2008
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
My amana softsound III Model DWA63AL doesn't seem to get dishes clean. I have cleaned filters and everthing seems to operate ok. Water temp good. any advice?
Many people are having trouble with poor performance due to recent EPA changes required in dish washing detergent.
If it makes as much water splashing noise as it used to but it still leaves residue and undissolved food behind...then it's probably the detergent. That's what does the work.
Mar 08, 2011 | Amana DWA63A Dishwasher
Our whirlpool dishwasher, gu3200 is leaving food residue on the dishes. We have taken it apart, cleaned everything, rinsed it with vinegar and the arms are rotating...yes the problem still persists. Any...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 22, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Leaves food residue on dishes, mostly glasses and only on top shelf after every wash.
heatman101
Jan 16, 2011 | Whirlpool 24 in. GU1200XT Built-in...
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
heatman101
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Soap (?) residue on dishes; also not getting them clean--food on
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
My dishwasher is leaving the glassware spotted and filmy. Silverware is also being left with a film or in some cases residue from food.
heatman101
Jun 25, 2010 | Frigidaire PLD4555RFC Dishwasher
Our Maytag Quiet Series 400 has stopped getting the dishes clean..It leaves residue and food on the dishes.My husband has taken it apart and there is nothing that he can find that might cause this.We have...
heatman101
May 03, 2010 | Maytag 24 in. MDB9750AW Dishwasher
The dishwasher is leaving residue on the lower rack dishes...everything except plates.
heatman101
Dec 29, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
Does not clean well and leaves detergent residue even after several cycles. Tried changing from detergent tabs to gel, no real change.
heatman101
Dec 21, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Amana 24 in. ADB2200AW Built-In Dishwasher Logo
1,746 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
