Question about Pioneer SD-P6093K 62 in. Rear Projection Television
Picture pulls in from sides a few inches after on for a couple of minutes you can see the red,blue and green lines around the smaller picture
    Brigadier General:
  • 4,090 Answers
The convergence chips are dying.The better option ois to call a professional to fix it as even if you change the board they have to be tunes correctly.
Thanks for using FIXYA
Posted on Sep 26, 2009
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
My RCA big screen picture messed up after one of my children fell nto screen?? How can I fix this
The picture on my 52 inch RCA Projection television has green, red and blue squiggly lines around the objects on the screen and the picture looks 3-D.
Oct 30, 2009 | RCA P52960 52" Rear Projection Television
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
Projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Red, bule, green lines do not line up together.
Having the same kind of problem, only mine occurs twenty or so minutes after start up and only on the left and right sides of the screen.
Jan 20, 2008 | Samsung HC-P4752W 47" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Aug 07, 2007 | RCA 32V420T 32" TV
Green picture
you might wanna look into the "flicker issue" with your set...If you've had it for a while a could be that it's just worsened over time and developed into a voltage leak. I have the same set and it went undetected for a couple of years due to poor quality cable signal..once I went to a clear signal (ie. directv) the issue was very noticeable, but by that time it had progressed. Eventually one of your guns will fail and the set will stop working all together (mine did just under 4yrs from purchase) and unless you have Sears warranty that WILL try to stick it to you. TRUST ME!!! Good luck.
Apr 01, 2007 | Sony KP-57WS500 57" Rear Projection...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
