Question about General Electric Dryers
Drum needs lubrication - General Electric Dryers
  • 430 Answers
My GE glides on a set of adjustable nylon pads at the front below the drum and a rear shaft. These are replaceable components through regular maintenance.
Since a belt drives the drum you would never lube the belt area and anything oily on the drum itself would attract dust and cause a mess.
Dryer overhaul is not rocket science, but if you get inside , after unplugging the unit....remember to clean away all visible dust.
Most driers have a hinged lid which swings up and back after releasing screws in the door area which point up to the underside of the lid, then inserting a putty knife along the sides near the front corners to pop the spring clips holding the lid down. Be gentle so as not to crack the enamel finish.
If your drier is clunking or grinding, I would recommend you pull the drum and overhaul front to back, mean while inspecting the element and gently cleaning it. Replace the glides or front rollers and the rear shaft and bushing together as they wear at the same time. Then remember to LEVEL the unit when done as centrifugal force wears out a non level drier.
Inspect the full length of belt for cracks by turning inside out. Before removing the belt note its installation pattern and tension set up area below near the motor.
If this helps please reply
Posted on Sep 26, 2009
Should belt on gas dryer be lubricated ? If so with what lubrication? Thanks, RIck rgl1950@live.com
NO!!..DO NOT LUBRICATE THE BELT, it will cause the belt to slip on the motor pulley or the drum.
If you have noise then you need to check you drum rollers, they are in need of lubrication or replacing if you have noise or maybe your idler pulley needs lubrication
This is a FREE answer
Please rate me
Jan 14, 2011 | Frigidaire FGR231A Gas Dryer
Why does my dryer make loud sqeeking noises while running
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as
3 in One oil.
Reassemble the dryer, plug back in.
This should solve your noise problem.
Please rate me
Dec 07, 2010 | Frigidaire FGR641F Gas Dryer
Squeling when drying clothes
u need to replace the dryer drum belt.
Mar 05, 2010 | Dryers
Loud rattling sound, drum still turns
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 12, 2009 | Miele T9800 Electric Dryer
Thumping sound from loose drum
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Sounds like the tub is rubbing against something
When you have the drum out you can check for rub marks on the drum also.
Good Luck,
I hope this helps
Oct 09, 2009 | Maytag Dryers
Making a noise when drum is turning.like a vibration
replace them.
you noise problem.
Good Luck,
I hope this helps
Oct 08, 2009 | Kenmore Dryers
When I turn my dryer on it has a clanking sound it drys the cloths but is loud.
Or may be an idler bracket that need to be lubricated or replaced.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers, and the idler arm bracket with pulley.
Check your drum rollers for flat spots, if they have flat spots on them replace them. If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil.
Then check your idler arm bracket to look for wear or need of lubrication, if it is worn then it may need to be replaced.
Good Luck,
I hope this helps
Oct 07, 2009 | Amana Dryers
The drum on my amanda dryer is making a noise as it go around.
Good Luck,
I hope this helps
Oct 02, 2009 | Amana Dryers
My dryer is sqeaking loudly when running
Squeaking usually comes from drum roller supports and/or the belt idler pulley needing lubricated. If the drum does not have drum roller supports under the drum, it will be equipped with a plastic drum glide the is located around the perimeter of the front drum facing. If this plastic wears down it will cause the drum to scrape against the metal bulkhead and make noise. If equipped, you need to replace the drum glide
The drum rollers (if equipped) can be lubricated with a light weight turbine oil (like the kind you would lubricate some ceiling fan motors with). Lubricate the roller wheels at the axle ONLY. Do not lubricate the wheels. The same is true for the idler pulley. Make sure you don't get any oil on the belt, or it will slip.
If you need instructions on how to reinstall the drive belt, repairclinic.com has dryer belt diagram illustrations under their "Repair Help" section. Look for the "Dryer Belt Diagram" link on the left hand side of the page. If your dryer is a GE model, you would use diagram M, D, or L (depending on the age of the dryer).
If you have questions, let me know. I hope this helps you.
May 06, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Dryers Logo
235 people viewed this question
Top General Electric Dryers Experts
Tim Whalen
Ned Halaweh
Ned Halaweh
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
