Knocking sound when drum is spinning - Washing Machines
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Washing machine shakes badly when spinning.
If not an unbalanced load, then it is an unbalanced drum. Turn the drum by hand when it is empty and it should spin smoothly (not freely because it is attached to the motor so there will be resistance). Can you hear a knocking or grinding? Push and pull the drum in and out, again any knocking? With your hands at 3 and 9 o'clock push with one hand while pulling with the other and rock the drum back and forth. Try it with hands at 12 and 6. Does it feel loose or makes a knocking?
Grinding is usually a sign if the bearings going or gone and knocking may indicate a broken drum holder (sometimes called a spider)
If everything sounds and feels okay then it may just be the machine is not level or secure. Rock the machine and if it wobbles check the feet and adjust until no more rocking. The feet do bend or adjust themselves over time, even making some kind of impression on the floor that makes it settle to a different level.
Jan 24, 2016 | Washing Machines
Washing machine knocking.
Does the drum wobble quite a bit or does it look normal? If it's wobbling it could be the drum casing knocking the internal structure. Might need a new drum spring if this is the case
Oct 20, 2014 | Washing Machines
Washing machine making a knocking sound
On this washer the problem is the washer drum rear bearing is worn out, a common problem and often caused by not using the correct detergent for a front loader, detergent is very corrosive, so special types are used in front loads to prevent soap residue corroding the drum bearing. Once the bearing go out then the struts that cushion the drum during the spin quickly follow.
Jan 20, 2012 | Hotpoint WMA44 Front Load Washer
Heavy mechanical knocking on final spin yet drum rotates freely when turned by hand and at low end drum speeds. Doesn't point towards the bearings. I have noticed that drum appears to be rotating slightly...
The knocking is the drum running out of balance due to the drum shaft being worn or corroded, or a worn bearing, a bearing can fail even though it may not sound noisy
Either way it is assoiated with the drum and entails a complete strip down, trust me on this, I do know what I am talking about.
Dec 03, 2010 | Zanussi FC1200W Front Load Washer
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
There is a noisy knocking noise on the spin.
could be your clutch, basket drive tube or drive block worn out, and if you can turn the drum by hand it sounds like the brakes or driveblock are worn
Feb 14, 2010 | Washing Machines
Whirlpool Duet WFW9200SQ has knocking sound located under drum under or near motor. Knocks during spin up and down cycle and on last highest spin.
the problem is a cracked spindle on the back of the drum. It most likely also tore up the grey plastic front shield.The only thing to do is throw the machine out sine the drum cost parts onle is over $400 for drum, and over $400 for the front plastic.l
Nov 12, 2009 | Whirlpool GHW9200L Front Load Washer
Drum Speed - Unstable
The spin bearing or basket drive may be worn. When these components are worn-they prevent the drum from spinning freely, and usually you hear a loud sound during the spin mode.
Sep 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
