Question about KitchenAid Architect® KEBS277S Electric Double Oven
Kitchenaid KEBS277D Self Clean Cycle resulted in shutdown...control panel blank...door locked. Not house circuit breaker...thermal or control fuse in oven, or thermostat? How do I get door unlocked if no power?
4 Suggested Answers
SOURCE:
SOURCE: Cleaning cycle failure
if it is not a brand new oven, i think the problem is with the top oven while the cleaning cycle the temp is way too hot and possible burned one of the wires above the oven. get that check out. good luck
Posted on Apr 15, 2008
  • 311 Answers
SOURCE: No power and door locked after starting self cleaning cycle
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
  • 100 Answers
SOURCE: oven door locked, can't get plastic cover of control panel off
you have to first remove the side trim there should be some screws in the side usaly 2 but sometimes 4 ---you could have replaced just the fuse for less than 20 dollers
Posted on Aug 09, 2009
Whirlpool self cleaning oven Model RBD245 door will not open after self cleaning cycle
Whirlpools are notorious for tripping the thermal fuse on the back of the oven but there is a thermal fuse to the control board also on most electronic control models. It is a good chance you will need to replace both fuses.
Oct 04, 2014 | Ovens
It is a free standing kitchen aid oven. I put it on quick self clean and it said it would end at 2:00. The panel went blank at 1:20 and it is past 2:00 and it is still locked. I checked the circuit br
Unfortunately KitchenAid ovens notoriously blow a thermal fuse when you use the self cleaning cycle, and if you're lucky that's all that happened. Hopefully your oven is still under warranty. If so, call KitchenAid customer service and they will repair it for free.
If you're handy you can check/replace the thermal fuse yourself (requires pulling out the oven and taking off the back panel, finding and replacing the fuse- be sure to turn off power and gas first).
Nov 13, 2012 | Ovens
Started the cleaning cycle, and cycle stopped with a beep. Power is still on. Error F5 E1. The door is now locked.
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at this LINK
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
Oct 23, 2010 | KitchenAid KEBC107 Electric Single Oven
Tried to self clean the oven and f9 appears and dr keeps beeping
HI. Your unit is programed to shutdown the self cleaning cycle if there is a problem sensed, within the door lock circuit. This fault will require you to inspect the door lock mechanism for separated wire connections, or a faulty circuit. The door Lock mechanism is located, just below the front section of the unit, where the control pad is located, or under the cook top hood, on a free standing unit. Use the procedure below to confirm the damage ot the circuit.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing.
Dec 24, 2009 | Frigidaire Ovens
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Oven door locked, can't get plastic cover of control panel off
Aug 09, 2009 | KitchenAid Architect® KEBS277S Electric...
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Nov 30, 2008 | KitchenAid Architect® Series II KEBS208S...
Please call KitchenAid/Whirlpool directly and ask to speak to the 'executive management team'
I had this fault for the second time and this time I spoke to the Exec Management team who said they were unaware of this as a common fault. My stove was ‘fixed’ free of charge – the fuse was replaced, again.
Please everyone who has had or is having this problem call again – this problem needs to be fixed, replacing the fuse each time or not using the self clean function is NOT a fix.
Mar 29, 2008 | KitchenAid Architect® KEBS277S Electric...
KitchenAid Architect® KEBS277S Electric Double Oven Logo
140 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
jdthefixer
Craig Butler
Craig Butler
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
