Question about Toshiba Satellite® P205 S6237 PC Notebook
After logging in the administator account the screen goes black ie no files ,folders and programs on the desktop.But the guest account is okay
  • Edward Jennejohn May 11, 2010
    xp or vista? not familiar with vista. had several friends tried it & switched back to xp! however, if you have an anti-virus prog. available, run it on your guest account. a virus, trojan, worm, or some other malware may be messing with your admin. account. also, i assume that you have a password for your admin. account. if your password gets you past sign on to a dead desktop, then, as you already know, something's screwing with your admin. privileges. try booting in 'safe-mode' and clicking on start and clicking on control panel, then administrative tools. this may allow you to find a fix-i'm talking xp in classic display mode. xp mode will display differently. i have a satellite too. older, but similar. if you don't know the f key to hit at boot-up, or possibly the delete key to bring up boot-up choices, check your dox. could be f2,f4,f8 or delete. need to start tapping the key as soon as boot -up starts!! if it don't work- shut down and try the next f key, or delete. one should work! good luck!
  • 788 Answers
Sounds like someone has removed all the user data for the administrator.
You may try a system restore but a restoration may be your only way out.
Posted on Sep 26, 2009
  • 615 Answers
Try to create new admin if it allow you by giving all rights and see how it works...Please see that grant me your approvals by rating my service and I hope that I can serve you again the future
Icant log in my computer.when log in,with in few seconds it logging off automatically
If running XP
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
Nov 13, 2012 | Dell OptiPlex 760 MT Desktop Computer
How to get computer off a tempory profile
which operating system ?
Every time that you log on to a Windows Vista-based computer that is connected to a domain, a temporary user profile is created.
When you log off the computer, the user profile is deleted.
This behavior usually occurs because the account that you use to log on to the computer is a member of one or more of the following groups:
•Guests
•Domain Guests
If this is a school/work computer then this is most likely the way the NetAdmin has set it up.
If this is your home computer then a temporary user profile is issued each time an error condition prevents the user's profile from loading.
You may encounter profile issues if you log on with a user in the Guests group.
You need to remove the user in question from the local Guests or "Domain guests" group and that should do it.
1. Click Start
2. Right click Computer and Select Manage
3. Select Local Users and Groups > Groups
4. Double click Guests
5. Check if the user that is having the issue is a member of the Guests group
6. If so, remove the user from the Guests group
7. Log off the workstation and log back on
8. Verify the profile is now local
or
Try following these steps and check if it helps:
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly.
Therefore, make sure that you follow these steps carefully.
For added protection, back up the registry before you modify it.
Then, you can restore the registry if a problem occurs.
a. Log on to the system by using an administrative user account other than the user account that is experiencing the problem.
b. Back up all data in the current users profile folder if the profile folder still exists, and then delete the profile folder. By default, the profile resides in the following location:
%SystemDrive%\Users\UserName
c. ClickStart, typeregedit in the Start Search box, and then press ENTER.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
d. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
e. Under the ProfileList subkey, delete the subkey that is named SID.bak.
Note SID is a placeholder for the security identifier (SID) of the user account that is experiencing the problem.
The SID.bak subkey should contain a ProfileImagePath registry entry that points to the original profile folder of the user account that is experiencing the problem.
f. Exit Registry Editor.
g. Log off the system.
h. Log on to the system again.
After you log on to the system, the profile folder is re-created
hope this helps
or
1. Use SFC / SCANNOW command to help you detect and fix any corrupted or missing system files.
1) Go to Start menu, expand "All Programs" - "Accessories" - "System Tools", right-click "Command Prompt" in the pop-up menu, select "Run as administrator", then input "SFC / SCANNOW" without quotation marks and press Enter.
2) When the "SFC / SCANNOW" command is running, this command will scan every corner of your system, and repair the missing or corrupted files.
2. Shift to another administrator user, if you don't have one, please create a new administrator account and log in.
3. Navigate to C:\Documents and Settings folder, backup the data of your original corrupted profile, then delete the corrupted profile and all the temp profiles.
4. Open Registry Editor (type "Regedit" without quotation mark in the start menu blank and open it), search for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\ProfileList, under the profileList subkey, delete the key named SID.bak.
5. Restart your computer; you will be able to log in the normal profile again.
hope this helps
Sep 23, 2012 | HP Pavilion G4 G6 G4-1000 Series...
My hp pavilion g series is loged on to a tempery profile so every time i log off everything is erased
•Guests
•Domain Guests
1. Click Start
or
hope this helps
or
hope this helps
How do I reset the password on the windows 7 home page
Windows has a built-in security system that requires a user to type in a password to get to his personal account.
Only an "Administrator" account holder can make software changes to the computer.
All other users, including Guest users, need the permission of an Administrator to make any system changes.
However, if you have a guest account and need to access the Administrator account to make changes, you can do so via the Command Prompt feature.
Log in to your Guest account in Windows.
Go to "Start" > "Search" and type in "windows/system32/cmd.exe" to find the Command Prompt feature.
When the file appears on the search menu, drag it to your desktop.
Leave the search window open.
Right-click the cmd.exe file on your desktop and choose "Rename."
Type "sethc.exe" for the new name and click on an empty area next to the file name to save the new name.
Right-click on the "sethc.exe" file and click on "Copy."
Go back to the open "windows/system32" folder and right-click anywhere in the folder.
Select "Paste" to put the "sethc.exe" file inside.
Choose "Yes" when asked if you want to overwrite the current file.
Go to "Start" > "Log Off." It will bring you back to the User Account menu.
Press the "Shift" key 5 times in a row.
The Command Prompt will open.
Type "net user administrator [password]" and insert a new password in the [password] section.
Press "Enter" to set your new password.
It will bring you back to the User Accounts menu.
Click on the Administrator User Account and type the password you just set to log in to the account.
Dec 22, 2011 | Compaq Computers & Internet
My guest account has a black screen cant log on but my icons are there?
Are you the administrator for this computer?...Are you the only one or the main one who uses this computer?....Is this you're computer?
You may need to create a new profile for administrator...or guest...Go to Control Panel...Users...Change Accounts...and make the changes....
Oct 29, 2010 | Computers & Internet
I have trouble downloading on MacBook Pro. Everytime i push the download key it goes to a black screen and doesnt download. I've checked the downloads folder but there is nothing there. I can download...
this sounds like a temp folder has your downloads and some software that is set to open at start up is keeping your files.
i suggest making a account or looking thorough your previous downloaded files
Jun 21, 2010 | Apple Customized 15" MacBook Pro Laptop...
I whent to control panel changed password it opened the windows but only parts i can use.i can not download or go to programs.it keeps asking for administrator.can only open this
hi ,
Obviously you have logged on as a guest user which restrict you from entering other files in the PC .
go back to the user icon on the control panel and log on as the administrator and you will be able to access all files .
Oct 03, 2009 | E-Machines eMachines Desktop PC
My administrator account is corrupt and i can not log into it, but luckily i have the guest account turned on but with this account i can not create a new account like an administrator one. so how do i...
Without using 3rd party pay-for tools, I would recommend locating the Windows CD that came with the machine. I would then boot to the CD, and use the Recovery Console option. When you get into the recovery console, you should be able to log in using the administrator password only. This doesn't load the Administrator profile, it just uses the password for permissions reasons. I would then navigate to the Documents and Settings folder (assuming this is XP) and rename the Administrator profile folder to something else. Once you rename this folder, restart the computer, log in as Administrator again, and Windows will create a new profile for the Administrator, and leave your old one alone. Once you're logged in, you can browse to the old profile and get your files and pictures back.
May 11, 2009 | E-Machines eMachines Desktop PC
I cannot delete the icons and folders on my desktop
make sure your log in account is in ADMINISTRATOR and not has guest
Nov 13, 2008 | Computers & Internet
Have a z708 lexmark printer can't instal to my computer have no instalation cd
  1. Uninstall any previous versions of the driver:
    1. Click on Start, Programs (Windows XP: All Programs).
    2. Go to the Lexmark folder and select the Uninstall program.
    3. Follow the prompts to continue the uninstallation.
    4. Restart the computer when the uninstall program is finished.
  2. Log on to the administrator account (generally the first account that is set up on the computer). Note: If you have purchased a ready-made system and did not install Windows yourself, you may need to contact your PC manufacturer to find out how to log on to your system's administrator account as this will differ from system to system.
  3. Install the printer again using the latest driver software. Note:
  4. Before you start downloading the software, make sure your printer is on and connected to the computer. If the software requires you to remove your cable during installation, it will prompt you to do so.
    1. Create a new folder on your desktop and call it Lexmark.
    2. Go to our Drivers and Downloads center.
    3. Note: The name of this site/page may be slightly different in your region/country.
    4. Click Printer Driver.
    5. Select the Related Product Name from the drop-down menu.
    6. Select your Operating System from the drop-down menu.
    7. Select the desired Language from the drop-down menu.
    8. Select the latest Driver File and click on the File Name to detach it to the Lexmark folder on your desktop (see step 1).
    9. Once the download is complete, open the folder and double-click on the file.
    10. When the WinZip Self-Extractor screen appears, click on When done unzipping file open:<the printer file name>. (The name will appear beneath this option).
    11. Click Unzip. The installation program should autorun. Follow the on-screen prompts to install the printer.
    12. If the installation program does not autorun, double-click on the newly created LXK___ folder for Setup.exe. An installation program will run. Follow the on-screen prompts.
    13. If you are prompted to install the printer for all users, click Yes.
    14. When the installation is complete, restart the PC.
  5. Try printing from the administrator account first and then from the user account that exhibited the problems in the first place. Both should print to the printer.
  6. If the administrator account works and the limited user account does not,
  7. click here for additional information.
Sep 16, 2008 | Lexmark Office Equipment & Supplies
Toshiba Satellite® P205 S6237 PC Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
