Question about Fenix Camping, Backpacking & Hiking
I have an LD10. The switch now only works intermitently. I replaced the tailcap and that didn't help. Any ideas would be appreciated. Regards, Russell
Have a utility here 1000 lms flashlight that stopped working. Replace nine aa batteries and still not working what should I try next
1st go back and verify that u installed them correctly , lights nowdays have a specific way the cells go in them or they don't work
2nd try a new light bulb (if it has one) bulbs do go from time to time u know
and last try fiddling with the battery cover , some lights have a tricky way the covers go on !!
Dec 20, 2016 | Camping, Backpacking & Hiking
New Beetle 2002 Hi-Beam lights only flash, don't stay on, what can I do?
I would test the relay to make sure it is still good and everything there is working like it is supposed to. I would also look at the switch and make sure noting came unplugged and it is still in good working order sometimes new parts are still bad.
Jul 26, 2015 | 2002 Volkswagen New Beetle
2001 nissan sentra neither one of my turn signal bulb are working tried replacing the bulbs that didn't work.also tried switching the pigtail that didn't work either any idea what the problem
I had this problem with my car. Is ur hazzard flasher working? if they are working and the turn signals are not working. Try replacing the hazzard light switch. If the hazzard are not working then the combination flasher unit is bad. its what controls the signals and flasher.
Nov 10, 2012 | 2001 Nissan Sentra
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Set the waterlevel to large load and the water spilled over the drum. The water did not stop automatically. Tried medium load and the same happened. Can you please help?
Your pressure switch is either bad or the line from the bottom of the tub is plugged and the machine has no idea how much water it is putting in. The pressure switch is located on the inside of the control panel, it should look something like the picture below, the tube that runs to the switch from the tub can be taken off and you can blow through it to clear it of any pluggage if it is not plugged the the switch is bad and needs replaced. Are you sure your water valves are working OK, I assumed so because you didn't mention that the water wont turn off. dcramer531_126.jpg
If you find this helpful a vote with the thumbs up would be appreciated for the free advice.
Thanks.
Jul 13, 2011 | Washing Machines
Flashlight only works when end cap is partially on. Will not work when cap is fully screwed in. New batteries installed.
Some models of the famous MagLite use this 'feature' as the on-off switch. I have several such myself.
Thanks foryour interest in FixYa.com
please remember to vote
thanks
a
Dec 05, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
Cruise Control, intermitent wipers acting up.
More then likely, the switch arm will have to be replaced, everything that contyrols your wipers and cruise are built into that left arm.
I hope this helps you.
Dec 31, 2008 | 2003 Jeep Grand Cherokee
Water Level control
if the pressure switch hose is not obstructed, check to see what happens if you try to **** thriugh the hose like a drinking straw
if you can and the pressure switch is wired correctly replace the pressure switch again
Jun 10, 2008 | Washing Machines
Right mouse button, wireless intellimouse explorer 2.0
the right and left buttons are controlled by a switch you need to replace the switch
Dec 07, 2007 | Microsoft Wireless IntelliMouse Explorer
Camping, Backpacking & Hiking Logo
37 people viewed this question
Top Fenix Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Fenix Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
