Question about Philips Televison & Video
Screen is showing a number of coller lines - Philips Televison & Video
  • 135 Answers
Hi it is a buffer board or video pcb has gone cheap and easy repair yourself
Posted on Sep 26, 2009
Fuel line plastic coupler leaking
inside the plastic fuel line ther are two seals you can get from the dealor a spacer inbetween and a coller on top holding it all in use a dental pick and a 3/8 socket to putit all togeather
Jan 24, 2012 | 1998 Buick Park Avenue
Getten sound but there is just lines all difrent collers strait up and down the screen
If it is in a corner and not from left to right then it sounds like a crack maybe at the bottom of set, but if it's linear, the same across then its a board problem.
Jan 14, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How do i remove adapters on tranmisson lines to install new radiator that came with quick coneect fittings?
They have little clips that slide in the side of the plastic coller at the fitting avary small screw drive can get under them so you can pull them out the rest of the way But you should replace them thats all that holds those lines in and you don;t want to lose a line while driving
Nov 16, 2010 | 2003 Chevrolet Impala
Hi there ... We have 4 lines in the office but on one of our M2000 series Meridian phones only the first 2 line buttons receive a dial tone ... How do add lines 3 and 4 to the next 2 buttons?
Programming is done on M7310, M7324 and T7316 sets.
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program the new lines on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 003:unaaign.
press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 004: unassign
press the chng key til the screen says appear&ring
press the Rls key when finished
Jul 03, 2010 | NorStar Meridian M7310 Phone
I NEED TO SET UP 4 PHONES TO HAVE A LINE 5 AND A LINE 6. THE BUTTONS FOR THE EXTRA LINES ARE PROGRAM WITH SOMETHING ELSE. HOW DO I PROGRAM THE PHONES TO HAVE LINE 5 AND 6.
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
press the next key (bottom right arrow) till it says 025(or 031):unaaign press the chng key till the screen says appear&ring
The display should say line 026(or 032): unassign
repeat the procedure the same as line 5 for line 6
press the release key when finished
Jun 23, 2010 | NorStar M7310 Corded Phone
Landrover freelander year 2000 light on dash board shows car tilting down hill with question mark
1)it is possible that your hill desent has been turned on. remady check gear stick sliding coller has not been engaged, press yellow switch and pull coller upward. 2) connector may have become dissconected from switch. remedy unscrew gearnob and press yellow switch and pull coller up and off , check wireing and connector the put all back together. next check your throttle peddle switch and or your reverse switch may need to be changed
Nov 22, 2009 | 2002 Land Rover Freelander
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
Oct 19, 2009 | NorStar Meridian M7310 Phone
Water in oil
check the timing case cover behind water pump or the oil coller in the radiator
Mar 18, 2009 | 1994 Dodge Ram 2500
Televison & Video Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
