Question about Toshiba TDP-ET20 DLP Projector
Thin black lines: projector TDP-ET20
I just bought this projector a couple of days ago, it was working fine until i plug in my Macbook pro with an HDMI cable. Ever since that operation, there are thin black lines allover the image. Is there a solution to this problem?
  • 74 Answers
Do a factory reset to the projector. In my experience that fixes alot of image problems.
Posted on Sep 26, 2009
Projector will not turn on from standby
Hi, did you ever get an answer to your question? I have an ET20 which, after several months of non-use, has now stopped working. The standby light is on, it makes a startup 'noise' but then does nothing. None of the other buttons are illuminated. Is this similar to your problem?
Dec 29, 2013 | Toshiba TDP-ET10 DLP Projector
Fuzzy images, MacBook Pro to NP500WS projector
Are you yielding the same results using a different laptop?
Jul 20, 2017 | NEC NP500WS LCD Projector
Hello, if I want to hook up an external audio device such as a speaker to my Toshiba TDP-ET20 DLP Projector, how do I do that?
Hey,
You will need to buy a digital coax to an RCA or analog Headphone cable. You will plug the digital coax end of the plug into your "coax out" connection on the back of the project.
The other end will depend on your speakers. If your speakers take an RCA connection (white and yellow cables) then you will buy a Digital Coax to RCA cable. If they take a regular headphone jack then you will need a Digital Coax to 3.5mm headphone jack converter, and plug the headphone jack into your speakers.
Mar 01, 2011 | Toshiba TDP-ET20 DLP Projector
Projector over heats while watching a movie. it just powers down without doing its usuall cool down exercise. maybe its a power issue but the temperature coming out of the projector is very hot.
I would check and make sure that the vent area is clear of dust. The vent being blocked with dust would cause the temperature to rise very fast while the projector is on.
Feb 26, 2011 | Toshiba TDP-ET20 DLP Projector
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace...
the tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Aug 07, 2010 | Toshiba TDP-T45U DLP Projector
I have a Toshiba TDP ET20 projector, the problem is that there is that it wont power up. There is a click when the power is turned on but no lights, including the main projector light, come on
if the fans come on but no lights, listen for a high-pitched whir. if you don't hear it, the colorwheel needs to be replaced. if you do hear it, replace the ballast. if no fans, replace the power supply.
Nov 06, 2009 | Toshiba TDP-ET20 DLP Projector
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
Lost manual
The manual is available online quite easily. Just google.
As for the audio connection, this is one big drawback of the TDP ET20. it only has digital audio out so you can't connect it directly to headphones or ordinary speakers. You need a home theatre system or an amplifier that accepts digital audio. Or you need to buy a seperate digital to analog audio converter.
Big pain.
Jan 15, 2009 | Toshiba TDP-ET20U DLP Projector
Will not turn on at all
you will probaly needs a new power supply in it. make shure that your getting power from outlet to. Hope this helps
Jan 13, 2009 | Toshiba TDP-ET20U DLP Projector
Toshiba TDP-ET20 DLP Projector Logo
332 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
