Question about Ionic Pro TURBO Air Purifier
THE INTERNAL IONIZING WIRES HAVE 3 TO 4 BLUE SPARKS STRIKING ONE OF THE BLADES??? AND ITS MAKING A CONSTANT,LOUD BUZZING NOISE ON ALL SETTINGS. I CLEANED THE BLADES LIGHTLY YESTERDAY,CLEANED THE OXYGEN FILTER,AND CLEANED THE INTERNAL IONIZING WIRES
  • cmosquitz Sep 26, 2009
    JUST TO ADD MORE INFORMATION REGARDING PROBLEM....THE AREA WHERE THE BLUE SPARKS ARE ON THE INTERNAL IONIZING WIRES IS ONLY ABOUT 1 INCH LONG TO MAYBE 1 1/2 INCHES LONG . IM NOT SURE IF THIS IS RELEVANT OR NOT.I ALSO JUST PULLED THE LEVER UP&DOWN AGAIN TO CLEAN THE INTERNAL IONIZING WIRES. TO NO AVAIL,THAT DID NOTHING!! STILL BLUE SPARKS??? AND LOUD,CONSTANT HIGHER PITCH BUZZING ON ALL SETTINGS!! I PURCHASED THIS MACHINE DEC/2008. WITH THE SOLUTION YOU GAVE TO MY PROBLEM,DO YOU THINK THIS IS THE ONLY THING IT COULD BE??? IS IT SOMETHING A GIRL COULD FIX (ME)??? AND IF SO ,WHAT TOOLS DO I NEED??? PLEASE HELP I DONT KNOW WHAT ELSE TO DO!!! AND I AM TRYING!! THANK YOU!!
    Genius:
  • 1,036 Answers
It is important to make sure thee parts are kept clean, so by cleaning them you have done what is normally required.
Check to make sure that there is adequate gap between the ionising wires and the surface it is arcing to, and that the wires are not bent or out of position, and that the blades are located properly.
If all seems straight and normal, then there may be higher than usual particulates in the air (pollen, dust etc) or the voltage regulator is defective - causing excess voltage to build up.
Ionisers usually fail by not building enough charge, but it is possible to fail the other way if a few capacitors dries out.
Usually you need a very high voltage for ionisers, so I suggest that it is a mechanical defect of alignment and spacing rather than an electrical one, so check all possible mechanical items first. - With power off obviously.
Posted on Sep 26, 2009
  • 788 Answers
The insulation on the wires connecting the ionizer, has broken down due to heat build up.
If possible you may need to replace the connections, if you have enough wire to strip back.
Once you remove the connections, you will see the wire is cracked or brittle
Honeywell Air Cleaner
Is the filter clean?
Are the ionizing wires clean? gently wiping them with 600 grit finishing paper should clean them up and restore perfomrance.
Is unit bent? If so it may be shorting out.
is unit fully seated and making contact?
Jan 31, 2012 | Honeywell FC37A1064 Air Purifier
Unit not working
You should also try rubbing the ionizing wires with 600 grit finishing paper first.
If that does not work, you can purchase the cells individually from many vendors. But I would give the finishing paper a try first. The ionizing wires do funny things to silicone compounds, it usually results in the ionizing wires getting slighly glassified, or coated with silicon dioxide..
Jan 30, 2012 | Honeywell (F50F1032) Air Purifier
My Ionic Pro keeps making a static-y noise when turned on. What is causing it and how can I fix it?
Hi jackieelling,
I work for the Ionic Pro company. Make sure you are also cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 05, 2011 | Ionic Pro TURBO Air Purifier
CLEANED FILTER. PUT THE FILTER BACK IN AND NOW IT IS MAKING A CLICKING NOISE. TOOK THE VACUM TO THE FILTER AND IT IS STILL MAKING THE NOISE
The clicking noise is the sound of the high ionizing voltage 'shorting' due to dirt or humidity or both which provides the pathway for discharge. Cleaning and completely drying the filter(s) does not always help, in this case switching the unit to a lower operational speed can mitigate this problem. New filter(s) may be needed to resolve the clicking.
Sep 13, 2010 | Honeywell QuietClean HFD-110 Air Purifier
Makes buzzing sound after cleaning blades
I keep the blades clean. Really clean. I'm a smoker, and you would not believe the crud that accumulates on those "blades"... <g>
First, I spray the blades with "PurplePower" cleaner/degreaser (from AutoZone), then I wipe them down with a sponge, then rinse with hot water. then dry them with compressed air (I have a compressor...).
FWIW, "Windex" works pretty good too, but... the degreaser really works well on the cigarette "residue"..
Second, there are two long wires inside that also have to be cleaned, periodically.
If your unit has the "pull-tab" cleaner, use it. One of my units has it. The other two don't.
On the ones that don't have the built-in cleaner, I stick a chopstick in through the rear vents, and CAREFULLY rub it against the sides of those wires, which "scrapes" the "white crud" off of the wires. Take your time. You will likely have to "change locations" several times in order to access the full length of both wires.
NOTE: those wires are fairly durable, but BE CAREFUL with them.
Either way, after cleaning the wires, I then "blow" the unit clean with compressed air.
Voila! No more buzzing. Until the next time the wires get "crudded up".
Mar 12, 2010 | Ionic Pro CA500 Air Purifier
I have the Ionic Breeze Hybrid GP from Sharper Image. It has an "arching" problem in the lower section of the grid. Can this be fixed? How? The unit goes into "drying" mode and the fans still run, but I...
had the same problem, sparking in the lower section. i cleaned the grid blades on the filter with a scotch brite pad thoroughly in the area that was sparking and cleaned the corona wires inside the back of the unit gently by rubbing with light grade sandpaper. the unit runs like new. give it a try.
Nov 27, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Electric arking between blades
check that one of the ionizing wires has not come loose also look at the plates and be sure they are straight a little bend can put them too close together and cause them to arc.
Aug 04, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic Pro makes weird buzzing noise
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Jan 03, 2009 | Ionic Pro TURBO Air Purifier
CA200 red light stays on, wont turn on
The machine is now part of a land fill elsewhere. Do to the company's attitude and refusal to help figure out what was wrong, they will not get another dime of my money. It seems that - when I tested - several of the components were zapped. I found at least one z diode out on the power supply end. I was not about to start fooling with the flyback xmfr. What amounted to the chrona wires tested fine. It is a neat idea but the company is worthless as far as customer relations. The "service" person could barely speak English (Engrish). They did not know a transistor from a fuse! I will recommend this product TO NO ONE. Ionic Pro - are you listening??? A VERY DISSATISFIED CUSTOMER!!!
Jul 07, 2007 | Ionic Pro CA200 Air Purifier
Clicking noise
I had the same problem.
We could put one cell in and it worked with out clicking. Putting the second one in solo however, it was clicking.
I looked closely at the second cell and discovered that two of the vanes on the side with the wires were bent at about 20 degrees off. Adjusting this and reinserting reduced the clicking but not completely. I pulled the cell and focused on the same two vanes and discover one was also bent in, gently pulled it back and no more clicking!
My wife had cleaned the filters and my 6 yr old and 4 year old had to help. I wonder how they got bent?!
We have had the cleaner for about 6 yrs and no problems until this last cleaning.
Be very careful in adjusting the cells. Aluminum does not like being bent and weakens each time it is moved, like pulling a tab off a beer can (of course the cells are made from much thicker and higher grade aluminum)!
Jan 23, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Ionic Pro TURBO Air Purifier Logo
165 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
