Question about HP OfficeJet 6210 All-In-One InkJet Printer
I install the priter on my hp computer, but I don't see the fax machine icon. Felix Gomez
I disconnected the hp officejet all-in-one from my computer and later reconnected it. Now it thinks its a fax machine, and won't print from the computer.
it (Hp officejet 4315v series FAX) must be set to default that's why it would not print.The default printer should be the Hp officejet 4315v series,the one without the word fax in the end.
Here's how you do it:
for windows XP operating system
  1. click on the start button on your computer.
  2. click on printers and faxes.If it is not on the start-up list you can click on control panel ,click on printers and faxes or printers and other hardware.
  3. in printers and faxes,it will display all the printers installed on your computer
  4. look for officejet 4315v series or officejet 4300v series then right-click on it's printer icon then left- click on set as default.
  5. try printing from the computer.
for windows vista operating system
  1. click on the start button on the computer
  2. in the search box,type in printers,hit enter key on the keyboard.
  3. in printers,it will display all the printers installed on your computer
If it does not print download the print diagnostic utility from the hp website.It is a helpful tool in diagnosing printing problems.I will provide you the link.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-91793-1&lc=en&dlc=en&cc=us&os=228&product=1138346&sw_lang=
Jul 09, 2011 | HP Officejet 4315v All-In-One InkJet...
How to scan of hp 4500 priter?
insert the documents to be scanned to the printer and command the scan from the software of the printer installed to your computer.
Oct 16, 2010 | Office Equipment & Supplies
Priter does't respond when i used it to print a document
Printer isn’t responding? Please check the following:
i. Is it powered on? If so good.
ii. Is the printer cable connected from printer to your computer? If so good.
iii. Check to see if printer is properly installed. Go to start/control panel/printers and faxes. When the box pops up with the list of installed printers check to see if your printer is listed. If not listed it means your printer is not installed. This also invariably implies that your printer cable (from printer to computer) is bad. Change it and your printer should install and you should be able to print then.
Dec 04, 2009 | HP DeskJet 3550 InkJet Printer
My fridge has a leak on the backside of the fridge behind the light bulb section. what can i look for or do to fix it. THANKS Felix Gomez
YOUR DRAIN IS CLOGGED. WHEN YOUR FREEZER DEFROSTS THE WATER HAS TO GO SOME WHERE. UN PLUG AND TAKE THE COVER IN THE FREEZER OFF. REMOVE ATH ICE UNDER THE COILS IS A SMALL DRAIN HOLE.THAT HOLE IS CLOGGED WITH ICE AND TRASH.
Oct 28, 2009 | Kenmore Refrigerators
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer will not scan
Hi!
Go to this site, http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140778&prodTypeId=18972&prodSeriesId=1140783&swLang=8&taskId=135&swEnvOID=228
Download and install the Driver, Drivcer universal, Aåålication, Firmware, Software, Uppdate and the Utility. That will make your All-In-One priter work properly again
Good luck
Nic
Apr 21, 2009 | HP LaserJet 3050 All-In-One Printer
My new 6310 HP won't receive faxes.
Hi
when you installed did you get the fax setup wizard during the installation. If not, you can get it by opening hp solution center-> settings-> fax settings-> fax setup wizard.
You can have the HP solution center icon in the desktop or try with hp Director.
if not you can look at the
hard-copy user guide walks you through all the setup variations, depending on what type of line you have, what components (answering machine, for example), and how you want to handle incoming calls and faxes.
Good Luck
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
Help needed with printer.
Go to your printers folder, normally (Start> Printers & Faxes) on menu or click on control panel and open Priters & Faxes Icon and see if your printer is in there. When you re-connected your printer you may have put it in a different usb port than previously, sometimes the pc assumes its a different printer. If the printer icon is in there you should be able to right click on it and an option to make printer go online or untick 'use printer offline'. If all fails, remove/uninstall the printer driver, dis-connect your printer, put in your printer driver cd (Best to install drivers first always) follow setup and connect your printer via any usb port and windows should find it and install the drivers automatically. Good luck.
Oct 13, 2006 | Canon PIXMA MP780 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
