Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker has ice in it but will not dump in bin!
Kenmore 106.55536400 Ice maker has ice in it but will not dump in bin! It is a ice in door side by side. The red light is blinking I just turned frig off and melted the ice and restarted. Red light still flashing
  • 1 more comment
  • glucashd Jan 02, 2009
    red light on ice maker blinks when door is open is this normal?
  • CHERKY Jan 25, 2009
    I HAVE THE SAME PROBLEM BUT DO NOT HAVE A SPEC SHEET AS DESCRIBED
  • Anonymous Mar 23, 2014
    The water is coming from the water dispenser and there is ice in the bin but it won't dump them i
  • 410 Answers
Before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Posted on Dec 17, 2007
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working andred light blinking
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Refrigerators
We have a GS6SHEXMB00, SR0645529 FRIG. and the ice maker stopped working. There is a light on the EYE panel that blinks red. Can you help? Rick
Aug 13, 2009 | Refrigerators
Ice maker broken
first if you take off that panel there is a circuit board . unlpug the board and put it back to gether if that dont work then replace it... i sometimes get away with both! i can also get you that part pretty cheap... here is my site. grab the number and give me a call thanks.
Apr 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Press and hold the flapper in dont block the optics there is a light beam that goes across and you will see a u shaped notch in your ice bin on the door this determins when the bin is full when the beam is blocked it thinks the bin is full ..After pressing and holding the flapper in what does the red light do keep blinking ?? if so how many time before there is a pause and repetes if it stays on solid i need to know that too
Jan 28, 2008 | Kenmore 53703 / 53706 Stainless Steel Side...
No ice...different question
Are you able to see if you can push a Q-tip or something up the fill tube line to see if it's frozen up inside there. It happens on certain units. You may need to take the Ice Maker out (easy) to get to the fill tube.
Feb 27, 2007 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
516 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
